| Thread Closed |
Boiling water by high frequency AC current |
Share Thread | Thread Tools |
| Jun29-06, 08:09 PM | #1 |
I've heard that if you pass a high frequency AC (26kHz?) current through water it boils.
Does anyone know if there is any truth to this? Has anyone ever done it? |
| Jun29-06, 08:12 PM | #2 |
The only way to make water boil is to heat it up. You can certainly heat it up by passing a current through it, but I doubt that the specific frequency is important. You will achieve the highest power transfer, of course, by matching your source's impedance with the impedance of the water.
- Warren |
| Jun29-06, 09:49 PM | #3 |
Many steam humidifiers work by passing 60Hz AC through water and boiling it. Just do a Google search for "electrode humidifier".
Note: They work rather poorly on de-ionized water (as expected), but for regular tap-water, they are pretty good. |
| Jun29-06, 09:54 PM | #4 |
Boiling water by high frequency AC currentso, if the resistivity is higher, i might make sense to do it at a higher frequency. |
| Jun29-06, 11:02 PM | #5 |
PS: (unrelated to above calculation, but) microwave absorption coefficients are tiny until you get to the GHz range. Peak absorption happens somewhere in the THz range. |
| Jul8-06, 12:28 PM | #6 |
To the original poster's question... there are people trying to build weapons using the idea you've described. It works using a high energy pulse from a big bank of capacitors. I think they used quite a high voltage, possibly a few kV or even tens of kV judging by the size of the arc, amount of noise and the flash. The discharge went off between a pair of electrodes and the water was either sitting between those at that point in time or injected between them, could have been as a mist or in droplet form - they didn't really go into the details of that. Might have had something mixed into it to improve conduction, maybe not. I would expect they've experimented a bit with different liquids. Anyway... big, big bang as the electricity boiled the water and turned it into a gas. Obviously, water expands a lot as it goes from a liquid to a gas so if the transitions occurs in a sealed tube that's only open at one end, anything loose placed in that opening will quickly vacate it. They didn't seem to have reached the tube stage and were just firing it in the open air with the discharge pointed at a plank of wood that was somewhere between 1/2 and 1" thick, which it was able to punch a hole through. Just yet another idea for how to kill other humans, and one that, like the hand-held gauss and rail guns, relies on a gigantic capacitor bank and so much juice per shot it's practically useless using currently available components. A lot of this is just the US millitary trying to reinvent the wheel in terms of human destroying technology in hopes of obtaining a more efficient splattering mode - or at least one that looks and sounds cooler, or is confusing enough for the general population that they can say it's okay to do it. And since RBJ mentioned it... ![]() How to boil water at room temperature, a video demonstration, courtesy of Fluid Design, of |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Boiling water by high frequency AC current
| Boiling water using electric current | General Physics | 11 | ||
| Boiling Water ? | General Physics | 8 | ||
| A pot of boiling water? | General Physics | 3 | ||
| Boiling points of water | Chemistry | 3 | ||
| Boiling water & salt | General Physics | 41 | ||
