NMR Theory and Analysis Problems
The discussion revolves around high-resolution nuclear magnetic resonance (NMR) theory and analysis, focusing on both theoretical understanding and practical application in preparation for an exam. Participants explore concepts such as nuclear shielding, chemical shifts, and signal interpretation in NMR spectroscopy.
  • Homework-related
  • One participant expresses confusion about high-resolution NMR theory and analysis, seeking help to understand the underlying principles.
  • Another participant explains that spinning charged nuclei generate a magnetic field and that energy is required to align these nuclei with an external magnetic field, which is detected by NMR.
  • The explanation includes examples of different environments for protons in compounds, noting how nuclear shielding affects the energy required to flip spin states, leading to multiple signals in NMR output.
  • Participants discuss the significance of the delta scale in NMR, referencing TMS as a standard reference point for chemical shifts.
  • One participant mentions the N+1 rule for signal splitting due to neighboring protons and how integration of peak areas provides information about proton ratios in different environments.
  • Another participant advises against delving too deeply into theoretical aspects, suggesting a focus on memorization and interpretation of spectra instead.
  • There is a side conversation about a music band, Iron Maiden, which diverges from the main topic of NMR.
Participants do not reach a consensus on the depth of theoretical understanding necessary for the exam, with some advocating for memorization and others suggesting a deeper comprehension of the concepts.
Some participants emphasize the importance of understanding chemical shifts and coupling constants, while others highlight the need to focus on practical interpretation of NMR spectra rather than theoretical details.
jimmy p
I have an exam soon and i am having problems understanding hi-res n.m.r. both theory and analytical sides. i don't understand why it happens and what it shows and stuff.
Can anyone help?
Chemistry news on Phys.org
Spinning charged nuclei (H+ in H-NMR) generate a magnetic field. In the absence of a magnetic field these particles orient themselves randomly. It takes energy to flip these states, to allign the field with some arbitrary external field B (generated by a beefy magnet). When this specific energy is matched by a pulse of radiation that is shot into the sample, the proton flips its state and then flips back and gives off energy that is equal to the amount that was required to flip it in the first place. The NMR detects this energy. Although the energy varies depending on what kind of environment the proton is in. For example, if the protons were in the same environment, it would take the same energy to flip their spin states and so you would have one signal. But in most compounds you have something called nuclear shielding, which is the nucleus being shielded from the full extent of B (magnet field B) because of the electrons that are orbitting it. So protons in different environments will feel the magnet differently, and so it may take more energy/less energy to flip their spin states.
eg's.
1) CH3CH2CH2Br will have three environments, (a) <CH3>CH2, (b) CH3<CH2>CH2Br, (c) CH3CH2<CH2>Br.
2) CH3CH2CH3 this is symmetric so you'd expect some identical environments of course, so (a) <CH3>CH2<CH3>, (b) CH3<CH2>CH3.
In 1) there are three different environments and therefore three different signals will show up on the NMR output. THe location of the peak(s) corresponds to the amount of energy that was required to flip the protons spin state. These peaks are relative to a reference point called TMS (Si(CH3)4) which is in a very electron rich environment and so appears upfield (on the delta scale). Okay, delta scale is defined as:
[tex]\frac{distance downfield TMS (Hz)}{operating frequency of NMR (MHz)}[/tex]
Upfield means more to the right, and downfield is more to the right. So, according to my little equation above we have Hz/MHz, which gives us like 1/1000000, or ppm! Very exciting. So everything is relative to TMS because TMS is so electron rich that other compounds are always (well, not ALWAYS but you know) not as shielded as TMS is.
Ugh, there's so much...
Okay, splitting. N+1 rule, very easy. A signal will be split if the environment it is located in is split by a neighbouring proton.
eg. in CH3CH2CH2Br, the CH3 will be split into a triplet. The CH2 next to CH3 and before CH2 is being split by two different environments and a multiplet is expected.
When you integrate the area under the peaks, you will get the ratio of protons in their enviroments. eg. when it's integrated it will give you a number like say 3 for environment a, and another environment (b) will give you 1. That means that a has 3 times the number of protons that b does. It does NOT neccesarily mean that there are 3 protons and one proton, there could be 6 protons and 2 protons you see...
Okay, that's about it for the theory anyway. There's also coupling constants which deals with the splitting patterns but anyway...
When I did these problems I made sure that I memorized all the important alpha (adjacent) and beta (next to adjacent) chemical shifts. Oops never mentioned that word, chemical shift is how much a signal is downfield from TMS.
http://www.colby.edu/chemistry/NMR/H1pred.html
That is a really useful website and I strongly suggest you master using it. Write down all the important shifts too and memorize them. Like, what's the chemical shift for an alpha carbon if there's an OH group attatched...hmmm. 3.2 ppm! +-0.5 of course.
End.
I would'nt get too deep with the theoretical aspects. My advice in memorization is to accept the facts, ponder about it a bit, and focus on the comparisons of different concepts or similar examples. You shouldn't have to get too deep, understand every theoretical aspect. Your teacher will most likely test you in your ability to interpret the spectrums.
Its not his teacher, it is an exam board and the exam boards suck!
Good Luck Jimmy!
Iron Maiden RULE!
YEAH! MAIDEN!
I'm going to see them in oine week. My buddy won some tickets.
MAIDEN! MAIDEN! MAIDEN!
AHHH!
HEY!i saw MAIDEN in December. They were AWESOME! you are going to LOVE them! MAIDEN MAIDEN!
I can still hear Brucie in my dreams...SCREAM FOR ME CARDIFF!, SCREEEEEEEEAAAAAMMM FOR ME CARDIFF!
oh yes.
12K
