What are the methods for solving impulse and momentum problems?
  • Thread starter Thread starter mikejones2000
The discussion revolves around impulse and momentum problems, specifically involving a bat hitting a baseball and analyzing a force vs. time graph to determine impulse. The original poster presents two distinct problems related to these concepts.
  • Mixed
  • The original poster attempts to apply the impulse-momentum theorem and considers the area under a force-time graph to find impulse. Some participants question the correctness of the original poster's calculations and suggest verifying units and vector considerations.
Participants are actively engaging with the problems, providing feedback on the original poster's methods and calculations. There is a mix of confirmations and suggestions for clarification, indicating a collaborative effort to explore the problems without reaching a definitive conclusion.
The original poster expresses uncertainty about their approach and the units of their answers. There is mention of a specific error tolerance for the second problem, which may influence the calculations being discussed.
mikejones2000
I am currently stuck on two problems:
#1 A bat hits a moving baseball. If the bat delivers a net eastward impulse of 0.9 N-s and the ball starts with an initial horizontal velocity of 3.8 m/s to the west and leaves with a 5.3 m/s velocity to the east, what is the mass of the ball (in grams)?
I set J=deltaP
.9=95.3+3.8)m
m=.9/(5.3+3.8).
#The second problem has a force vs. time for an impulsive force graph and asks: The force shown in the figure below is the net eastward force acting on a ball. The force starts rising at t=0.012 s, falls back to zero at t=0.062 s, and reaches a maximum force of 35 N at the peak. Determine with an error no bigger than 25% (high or low) the magnitude of the impulse (in N-s) delivered to the ball. Hint: Do not use J = FΔt. Look at the figure. Find the area of a nearly equally sized triangle.
I am sure tthis problem is very simple but do not have a confident approach for some reason, I presume I find the time when it peaks at 35 N(.062-.012) and use this as my base? Then I would apply A=.5(35)(.062-.012)?
Any help would be greatly appreciated.
It seems like you methods are correct, is there a problem with you answers?
Also if this graph is the graph for the basball and bat in part one the area of your approximate triangle should be approximately .9Ns
I got 0.0989 for the first problem, I am not sure if its in kilograms or grams and
0.875 for the second one. I know I got at least one problem out of the three assigned and presume it has to be one of these because the other is a multiple choice problem. Thanks in advance for any help.
If you're using SI units for your working it will be Kg.
With regards to question 1 remember that delta p is pf - pi. Also these are vector quantities but I think you've taken that into account just a reminder.
For question 2 if they say use a triangle then use a triangle it should be fine. The area under the curve would normally be determined by the integral of F(t) but since its not given the triangle method should give a fair approximation.
  • · Replies 24 ·
9K
