Radioisotopes with the greatest activity?
  • Thread starter Thread starter danago
    Activity
The discussion revolves around comparing the activity of two radioisotopes with significantly different half-lives: one with a half-life of 8 seconds and another with a half-life of 1600 years. Participants are exploring how half-life influences the rate of decay and, consequently, the activity of the samples.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between half-life and activity, questioning whether a longer half-life implies greater activity. Some explore the mathematical representation of activity and its dependence on the decay constant and number of undecayed atoms.
There is an ongoing exploration of the implications of half-life on activity, with some participants providing equations to support their reasoning. While there is a suggestion that the sample with the shorter half-life has greater activity, explicit consensus has not been reached.
Participants are considering the implications of stability and decay rates, with some questioning the assumptions underlying their interpretations of the half-lives and activity. The discussion reflects a mix of intuitive reasoning and mathematical analysis.
danago
"You are studying two radioisotopes, each of which contain the same number of undecayed atoms at the instant the activity of each is measured. Sample X has half life of 8 seconds, while sample Y has a half life of 1600 years. Which sample has the greatest activity? Explain."
Im not sure. I would have said the 1600 year one, since it takes much longer for the activity to decrease, but I am not sure. Any confirmation on this?
Activity is the rate of decay of radioactive nuclei and is represented thus;
[tex]A = - \frac{dN}{dt} = -\lambda N[/tex]
where [itex]\lambda[/itex] is the decay constant and is related to the half life thus;
[tex]T_{\frac{1}{2}} = \frac{\ln 2}{\lambda}[/tex]
So, combining the two equations we obtain;
[tex]A = - \frac{\ln 2}{T_{\frac{1}{2}}} \cdot N[/tex]
Where T1/2 is the half life. Can you use the above to now answer your question?
Thanks for the reply. With that last equation, can i say that as the half life approaches infinity, activity approaches zero? Or am i completely off track?
You are not off track. And that makes sense since an infinite half life means that the element is perfectly stable, which then implies that there are no decays and hence no activity.
So the answer to the question would be the 8 second substance then?
I would agree with that :smile:
yay :)
Thanks very much :)
danago said:
yay :)
Thanks very much :)
My pleasure.
As Hootenany's fromula shows you, the activity depends on two factors: the number of particles present and the half life.
If you have a trillion nuclei with a half life of 8 seconds and a trillion nuclei with a half life of 1600 years, in which sample will you observe more decays per second? Here the numbers of nuclei are the same so it leaves only the effect of the half life.
The one with the half life of 8 seconds decays much faster than the other one, right? So just using simple intution, which simple would you expect to have a larger activity? (and then you can confirm this with the equation)
  • · Replies 20 ·
