Stress-Energy tensor of a rotating disk
The discussion focuses on the stress-energy tensor of a rotating disk in the context of general relativity. It establishes that, in relativistic terms, the stress-energy tensor lacks pressure or tension terms when compared to engineering definitions, which assume a comoving frame. The author references the continuity equation and presents equations for radial and circumferential pressures, concluding that the absence of radial tension terms maintains the integrity of the continuity equation. The canonical reference for this topic is identified as "General Relativity and Gravitation" by Held, particularly the first chapter.
  • Understanding of the stress-energy tensor in general relativity
  • Familiarity with continuity equations in relativistic physics
  • Knowledge of cylindrical coordinate systems in physics
  • Basic concepts of rotating frames and metrics in general relativity
  • Study the stress-energy tensor in various frames of reference
  • Learn about the continuity equation in general relativity
  • Research the implications of rotating frames on physical laws
  • Read "General Relativity and Gravitation" by Held for in-depth understanding
This discussion is beneficial for physicists, particularly those specializing in general relativity, as well as students and researchers exploring the dynamics of rotating systems and the mathematical formulations of stress-energy tensors.
pervect
Staff Emeritus
Insights Author
I'm getting a rather crazy looking result, but I'm beginning to think it may be right.
Unfortunately, I haven't been able to find any specific references on the topic to check my sanity level.
Basically, I'm finding that in relativistic terms, there are no pressure (or tension) terms in the stress-energy tensor of a rotating disk. (Perhaps I should say - there are not necessarily any such terms).
This is different from the engineering result. But I believe that the difference is due to the fact that in engineering, the stress-energy tensor is taken to be comoving with the disk. i.e:
http://en.wikipedia.org/wiki/Stress-energy_tensor
Warning: In solid state physics and fluid mechanics, the stress tensor is defined to be the spatial components of the stress-energy tensor in the comoving frame of reference. In other words, the stress energy tensor in engineering differs from the stress energy tensor here by a momentum convective term.
If we adopt a cylindrical coordinate system (t,r,theta,z) the stress-energy tensor is just
[tex] \begin{array}{cccc}<br /> rho(r) & 0 & p(r) & 0\\<br /> 0 & 0 & 0 & 0\\<br /> p(r) & 0 & 0 & 0\\<br /> 0 & 0 & 0 & 0\\<br /> \end{array}[/tex]
rho(r) and p(r) are two arbitary functions, representing the energy density and the momentum density.
Rigidity of the disk will impose a relationship between p and rho, uniformity of the disk will give us another constraint.
If this is NOT correct, then my understanding of the continuity equation [itex]\nabla_a T^{ab}[/tex] is wrong and needs to be fixed. The above stress-energy tensor satisfies the above equation - adding any radial tension terms would spoil this happy state of affairs.<br /> <br /> Comments? References? Brickbats?[/itex]
This may or may not be useful to you, but if I recall correctly, the canonical reference for the (relativistic) rotating disk is a chapter in "General Relativity and Gravitation", Held, Volume 1. I believe that it's the first chapter but it's been a couple of years since I've read a copy of this book so I'm a bit iffy on the details.
Thanks, it sounds like it might be worthwhile getting on interlibrary loan. (I think I found the book you mean in the Library of Congress catalog).
I think I'm getting sensible-looking results, though.
In non-rotating coordinates, the continuity equation I'm getting is:
[tex] {\frac { {\frac {d Prad}{dr}} r<br /> +{\it Prad} -{r}^{2}{\it P\theta} }{r}}<br /> [/tex]
Prad being the radial pressure, P[itex]\theta[/itex] being the circumfrential pressure.
This equation implies that if [itex]P\theta[/itex]=0, Prad=k/r^2. For a finite pressure at r=0, Prad=0 if Ptheta=0.
Converting to co-rotating coordinates
(t1=t,r1=r,[itex]\theta[/itex]1=[itex]\theta-\omega[/itex]t,z1=z)
changes the metric
g_tt = -1 + r1*w^2
g_t[itex]\theta = \omega r1^2[/itex]
The stress-energy tensor in this new metric should now have T^0j=0 because everything is stationary in the new coordinates.
In this corotating metric, the continuity eq becomes
[tex] {\frac {-\rho {\omega}^{2}{{\it r1}}^{2}+<br /> {\frac {d Prad}{d{\it r1}}} {<br /> \it r1} +Prad - {\it P\theta} {{\it r1}}^{2}}{{\it r1}}}=0[/tex]
and we now see [itex]\rho r \omega^2[/itex] terms in the radial pressure which I initially expected.
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 21 ·
