Why is copper wire preferred over iron wire for solenoids?
The discussion revolves around the preference for copper wire over iron wire in the construction of solenoids, focusing on the electrical properties and practical considerations involved in this choice.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the differences in electrical properties between copper and iron, particularly regarding resistance and conductivity. Questions arise about the implications of these properties on the strength of the magnetic field generated by solenoids. Some participants also discuss the physical characteristics of the materials, such as insulation and strength.
The discussion is active, with participants providing insights into the reasons for using copper, including its lower resistance and better conductivity compared to iron. There is acknowledgment of the importance of wire thickness and insulation, as well as considerations regarding the mechanical strength of the materials.
Participants note the potential issues with using iron, such as oxidation and the need for insulation, while also considering the trade-offs between material strength and electrical performance.
anzgurl
1.Why is a copper wire was used in a solenoid rather than a iron wire ?
Don't you have any ideas of your own? What differences are there, in electrical properties, between copper and iron? (Gold is even better but expensive!)
well simply because copper has lower resistance than iron. thus with more electricity flowing through(copper), u can generate a stronger magnetic field.
I'm sure you mean current.:wink:
The comments already given about resistance are certainly correct. Because the magnetic field of a solenoid depends on the number of turns per unit length of the solenoid, it can be important to have the windings as tightly spaced as possible - which means making them as thin as possible. Since the electrical conductivity of copper is higher than steel, copper wires can be thinner.
There is also the problem of insulating steel and the deterioration of steel through oxidation (rust). A thin varnish coating on copper will create a good permanent insulaton. Steel electrical wire is often copper coated for this reason. Steel has the advantage that it is stronger than copper. So if strength is important, you may want to use copper coated steel wire for the solenoid.
AM
  • · Replies 31 ·
