Newton's G or Planck's Length?
  • Context: Graduate
  • Thread starter Thread starter arivero
    Length
The discussion centers on the comparison between Newton's gravitational constant (G) and Planck's length (L_p) as fundamental constants in physics. Participants explore the implications of defining G in terms of other constants like the speed of light (c) and Planck's constant (h), as well as the mathematical relationships and physical interpretations that arise from these definitions. The conversation touches on theoretical frameworks, including quantum field theory and string theory, and considers the dimensionality of physical constants in various contexts.
  • Some participants suggest that if Planck's length is fundamental, one can recover gauge quantum field theory in a single limit, while a double limit is needed for Newton's constant, leading to complexities when considering limits of h and L.
  • There is a proposal to derive G from c, h, and L_p using Planck relations, with challenges posed regarding the implications of this definition in classical and relativistic contexts.
  • One participant expresses a preference for gravity (g) as the most fundamental constant, arguing that while other constants can be derived from it, the reverse is not possible.
  • Another participant counters that G, like h and c, is a human construct dependent on anthropometric units, questioning its intrinsic nature in the universe.
  • Some participants discuss the significance of Planck mass as a more fundamental quantity than the kilogram, emphasizing its less anthropocentric definition.
  • There are mentions of string theory and loop quantum gravity (LQG) positing Planck length or Planck force as fundamental quantities, raising questions about the nature of these constants.
  • Concerns are raised about the dimensionality of space and time, suggesting that the form of constants like G may depend on the number of dimensions considered.
  • References to Zwiebach's book highlight discussions on electromagnetism, gravity, and Planck length in higher dimensions, with some participants noting the implications for Einstein-Hilbert action.
  • There is a technical exploration of how the units in the Einstein-Hilbert action relate to the dimensionality of constants, suggesting that the time coordinate differential introduces additional factors.
Participants express a range of views regarding the fundamental nature of G and L_p, with no consensus reached on which is more fundamental. The discussion includes both supportive and critical perspectives on the definitions and implications of these constants.
Participants note the complexity of deriving constants in different dimensional frameworks, and the discussion reflects various assumptions about the nature of these constants and their interrelations.
arivero
Time ago there was an interesting article on the arxiv title "Trialogue", about h, c, and G as fundamental dimensionful constants. A doubt can be raised additionaly: which is the more interesting mathematical object, [tex]G_N[/tex] or [/tex]L_p[/tex].
If Planck's length is the fundamental object, one can recover Gauge QFT in a single limit L-->0, but a double limit is needed to recover Newton's constant: h-->0, L--->0. And the single limit h-->0 is rather strange, because if Planck's length (and c) remains finite then G goes to infinite.
So you regard G as derivative from c, h, and l_p via the Planck relations? What do you get (you made the claim; you do the work:biggrin: ) when you plug this definition of G into Newton's inverse square relation or Schwartzschild's expression for the horizon in his geometry?
If I had to vote for 'the most fundamental' constant, it would definitely be gravity [g]. I can see how you might derive other fundamental constants using 'g', but, not how you could derive 'g'.
[tex]F= {l_p^2 c^3 \over \hbar} {m_1 m_2 \over r_{12}^2}[/tex] :biggrin:
[tex]R_M=2 M {c \over \hbar} l_p^2[/tex]
And yes, here is the paradox: F is a classical quantity, so not c neither h should appear; and R is a relativistic unquantised object, so we do not expect h to appear. If we want to be free to remove h in the second expression, lp^2 must go to 0 too. And if we want to remove both h and c in the expression for Newton force, we need a different kind of dependence of lp.
Still, string theory postulates that the fundamental quantity is lp (or its cousin, Planck force) and the same claim seems to emerge from LQG.
Hmm, in function of the stress tension of the fundamental string, call it T_P, we should get
[tex]F\propto = {c^4 \over T_P} {m_1 m_2 \over r_{12}^2}[/tex]
and
[tex]R_M\propto =2 M {c^2 \over T_P}[/tex]
so at least here we do not have explicit h around, but the non relativistic limit is still to be got when c goes to infinite, then again T_P must go to infinity fast enough to counterweight c in Newton's force.
i presume you mean [itex]G[/itex]. why is that so fundamental? like [itex]\hbar[/itex] and [itex]c[/itex], it just a number that is a human construct (as a function of the anthropometric units we use). there is no intrinsic strength of gravity in the universe, but using our units like meters, kg, and second, we measure that strength.
rbj, I already stressed "dimensionful" in the starting post of the thead. You can argue that dimensionful quantities are human constructs, but still Planck's Mass seems more fundamental than, say, the kilogram; I expect you notice the difference.
certainly the Planck Mass is more fundamental (being less anthropocentric in definition) than the kilogram. i just couldn't understand what the other poster meant by "g" other than G.
i tend to think that the Planck units (with a possible substitution of [itex]4 \pi G[/itex] for [itex]G[/itex] and [itex]\epsilon_0[/itex] for [itex]4 \pi \epsilon_0[/itex]) simply have to be the natural units of physical reality. it obviates the need to answer the questions of why Nature would bother to take some quantity (say, flux density) and scale it with some number to get some other directly related quantity (in this case, field strength). those conversion factors just go away so we wouldn't need to try to explain why Nature would be fiddling with them. (there are always the dimensionless quantities like [itex]\alpha[/itex] that still need explaining.)
rbj said:
c (with a possible substitution of [itex]4 \pi G[/itex] for [itex]G[/itex]
Posibly better, [tex]c^4/G[/tex] instead of G. Two reasons: it is the string tension :biggrin:, and it is the quantity one needs to match the units of Einstein-Hilbert action.
Just a comment: It seems to me that there is an implicit assumption about the dimensionality of space[time] here. For example, if one generalizes the Poisson equation to n-dimensions, the analogue of the Newton constant "G" would depend on n. A similar argument could be applied to the Coulomb constant. One implication is that the resulting "dimensionless constants" would take different forms in different spacetime-dimensions.
Hmm, it should if you extract it from the original Newton formula. On the very very opposite side, string tension is always a tension. Just now I am not sure which is the position of Einstein-Hilbert action between these two extremes.
Chapter 3 (and problems 3.9, 3.10) of Zwiebach's book has an interesting discussion of electromagnetism, gravity, and the Planck lenghth in higher dimensions.
A pity, Zwiebach lecture notes do not include problems 3.9, 3.10.
It is very interesting the notation [tex]G^{(n)}[/tex] meaning this dimension-dependent Newton constant.
Still (see http://pancake.uchicago.edu/~carroll/notes/ or the wikipedia), it sounds different when we look at Einstein-Hilbert action:
[tex] S= {c^4 \over 16 \pi G} \int R \sqrt {-g} dx^4 [/tex]
and Zwiebach does not care about it in that chapter.
OK, they are not so different. I think I get it. The point is that the units of [tex]\int R \sqrt {-g} dx^n[/tex] are not L^(n-2) but [tex][L]^{n-2} \over [c][/tex], and thus the compensation factor gets an extra c, becoming [tex]c^{4}/ G^{(n)}[/tex]. This happens because the time coordinate differential, dx^(0), carries this factor c around to be homogeneus with space. Is it?
  • · Replies 25 ·
  • · Replies 26 ·
