| Thread Closed |
parallel plate capacitor capcitance question? |
Share Thread | Thread Tools |
| Jul6-06, 02:13 PM | #1 |
I know that the capacitance is depended on area and distance etc etc. However, can someone explain to me the statement that as the area increases the, Elctrical field decreases.
C would increase because of the area, and V would decrease because of the E, so for this scenario would the charge be constant or increasing. Can someone show in equation forms, please show how E would decrease. maybe a little concept too. This is something I cant understand. |
| Jul6-06, 02:22 PM | #2 |
Hello mazinse,
The formula to determine the capacity of a parallel plate capacitor (distance of the plates being d) would be: [tex]C=\epsilon_0\epsilon_r*\frac{A}{d}[/tex] As you said with increasing area A the capacity increases as well. Now the formula for the electric field: [tex]E=\frac{U}{d}[/tex] [tex]U=\frac{Q}{C}=\frac{Q}{\epsilon_0\epsilon_r*\frac{A}{d}}[/tex] [tex]E=\frac{Q}{\epsilon_0\epsilon_rA}[/tex] As the area increases the electic field decreases. In your scenario only the area is increased, the charge would remain the same. Regards, nazzard Edit: Aaaahhhh, the forum won't stop eating my equations up
| Jul6-06, 11:20 PM | #3 |
yes it's wonderful using the energy equation, this works out nice. However, why does electrical field decrease, can u give me a conceptual explanation.
| Jul6-06, 11:36 PM | #4 |
Recognitions:
parallel plate capacitor capcitance question?To answer your question, the total E field at a point is ismply the vector sum of the E fields produced by all the charges, right? Now imagine uniformly spreading the same amount of charges over a larger area. Then of course the total E field will be weaker (since almost all the charges will be farther away from the point). |
| Jul8-06, 01:56 PM | #5 |
ok ok that is helpful, but why is charge constant when A goes up, what controls it? If I increase like the current or voltage of the power supply, would the charge change then? But that would change potential difference too then right? And everything would be changed
| Jul8-06, 02:17 PM | #6 |
It is the change in potential difference applied that causes the change in charge.
If charge were to increase by m times and area increased by n times the change in the electric fieold would be m/n times the original, as can be seen by using the relation posted by nazzard, [tex]E=\frac{Q}{\epsilon_0\epsilon_rA}[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: parallel plate capacitor capcitance question?
| Non-parallel Plate Capacitor | Introductory Physics Homework | 2 | ||
| Simple Parallel-Plate Capacitor Question...please HeLP!!! | Introductory Physics Homework | 6 | ||
| A proton is released from rest at the positive plate of a parallel-plate capacitor. | Introductory Physics Homework | 16 | ||
| Parallel Plate Capacitor | Introductory Physics Homework | 1 | ||
