Question on special relativity
The discussion revolves around the implications of special relativity, particularly focusing on the scenario of an observer moving towards two light sources. Participants explore the apparent contradiction regarding the simultaneity of light rays reaching the observer and the effects of relative motion on their perception of these events.
  • kknull presents a scenario where an observer moves towards one of two light sources and questions how the light rays meet at the observer's position.
  • Some participants argue that the perception of simultaneity depends on the frame of reference, suggesting that the rays meet at the midpoint from the sources' perspective but not from the observer's perspective.
  • Others assert that the observer will encounter the light from the nearer source first due to their motion, challenging kknull's interpretation of the situation.
  • There is a discussion about the relativity of simultaneity, with some participants stating that the rays were not emitted simultaneously from the observer's frame of reference.
  • One participant uses a classical mechanics analogy involving balls to illustrate that if the observer moves towards one source, they will receive the light from that source before the other.
  • Another participant emphasizes that the speed of light remains constant at c, regardless of the observer's motion, but acknowledges that the observer's position changes over time.
  • Some participants express confusion about the implications of the relativity of simultaneity and how it leads to a circular argument regarding the meeting point of the light rays.
  • There is a suggestion to disregard the sources and focus solely on the light rays, arguing that their relative speed remains c regardless of the observer's motion.
Participants do not reach a consensus. There are multiple competing views regarding the simultaneity of the light rays and the implications of the observer's motion, leading to ongoing debate and confusion.
Participants express uncertainty about the relativity of simultaneity and its implications for the scenario. The discussion reveals a lack of agreement on the interpretation of the observer's experience versus the sources' experience.
kknull
hello,
imagine 2 source of light. In the middle there is an observer who is moving towards one source at a determined speed s. The 2 sources send a ray of light when the observer is perfectly in the middle. In the observer's point of view, the 2 rays of light travel towards him at the relative speed of c, so they meet exactly at the same point on the observer; this is impossible because in the meantime the observer has traveled for some space, so the 2 rays have to meet together not in the middle, but near a source.
I cannot solve this problem, can you help me?
thank you.
regards, kknull
P.S. Excuse me for my bad english!
Well it all depends on from which frame of reference you measure this.
I am not sure what the problem is, there is no problem actually!
well, if you see the events from sources' point of view, the ray of lights meet together at the middle. If you see the situation from observer's point of view, they meet next to a source, it's impossible!
No, from both the sources' view and the observer's point of view the rays meet at the middle. What they will[ disagree about is whether or not the rays both started from their sources at the same time. According to the sources, they do. according to the observer, they do not. This is known as the Relativity of Simultaniety.
It seems kknull that you have not as of yet accepted the view that distance and duration are not absolute properties but properties that depend on the frame of reference. Until you do the effects of relativity will remain to you impossible.
You're trying to tell me this "the rays will not meet at the observer because the rays will not meet at the observer!( according to the observer, they do not)" But that is the point, I do not understand the relativity of simultaneity: if the rays start simultaneosly (according to the sources), the rays will have the same speed c for the observer, so they must meet at the observer!
Thank you for your answers, Janus and Jennifer.
P.S. I do not understand also the famous Einstein's example of the train, this is the point.
kknull said:
hello,
Stop. Right here. This is wrong. If the observer travels towards a light soure he will:
1. FIRSTLY encounter the wavefront from that particular light source
2. LATER encounter the wavefront from the other light source.
This is called "closing speed" and it is well known in physics in general, relativistic or classical.
thank you.
regards, kknull
The rays will still meet SIMULTANEOUSLY in the middle of the distance between the light sources, they do NOT meet simultaneously on the moving observer.
so in this case it is no longer valid the rule that relative speed of light is always c?
It is always valid that the relative speed of light is c. However, if the observer was in the middle at the time the light was emitted (measuring time in the source frame), and he is moving, then he will no longer be in the middle when the light gets there. Hence, the light rays cannot meet where he is.
If we consider the observer's frame, we have the added complication that the relativity of simultaneity means that the light rays were not emitted at the same time - at least, not as the observer measures time.
Not at all. The speed of light is not inifinite, hence it takes time to reach the observer.
If the observer moves, well then one will reach him before the other. T
his is not even relativity but a simple observation we can make with things like balls.
Have two people one left and one right of you throw a ball with the same speed at you.
At the same time you move in the direction of one of them. Then surely you woud understand that one of the balls will reach you sooner.
If the speed of light were infinite then you would be correct. But it is not.
:smile:
how can you demonstrate it?
you're trying to tell "the two rays don't meet at the observer because when "the observer measures time" the two rays don't meet at the observer (they are not simultaneous) we are in a closed circle.
:smile:
mmm... classical mechanics told me that if I am 10m far from an object and our relative speed is 1m/s, then we will reach in 10s.
So, if the observer is 10m away from both sources, and have the same relative speed with the 2 rays of light (c), then the 2 rays will meet at the observer.
That is not what you wrote at all:
So, do you understand it now?
the source and the light aren't the same things. you have to delete the sources from your imagination. There are only two rays of light which start at the same distance from the observer. So it has no importance that I am moving towards a ray of light, simply because I CAN'T, the relative speed is always c, the sources have no importance in this part of the problem.
So do you want help in understanding a problem you have with relativity or are you here to explain that it is all wrong? :confused:
If at the start of this problem you are at the center and you start to move when the light beams are fired (according to preset, synchronized clocks), obviously you will no longer be at the center when the light beams get there.
So then, is your question really about how you can still measure both beams of light approach at C? Ie, if they are both baseballs and not beams of light, fired at 100m/s toward the center and you are moving at 10m/s, you will measure one at 110m/s and the other at 90m/s.
exactly, if I have balls they change relative speed, (ie 110,90), but if I have light, the relative speed is always c!
kknull said:
hello,
thank you.
regards, kknull
The key point is this: when you say that the the two sources send a light beam when the observer is in the middle, you are implicitly saying that they send a light beam at the same time . But who decides that they are emitted at the same time? Someone in the frame of the light sources or the oberver moving at some speed relative to the light sources?
That is the key issue. If it's as seen from the light sources, then yes, the light beams will cross at the middle of the two sources and they will reach the observer at different times.
SO how does thing look like from the point of view of the observer? What happens is that he/she will see the two light beams emitted at different times . He will see one beam emitted before the other and that's what will explain from his/her point of view that the beams don't reach him/her at the same time.
Hope this clarifies things.
Patrick
Patrick
Yes, this is the key point: is there a logical explanation that for the observer the 2 rays are not simultaneous, or it is like "it is because it is"?. As I say before, we are in closed circle, we are trying to demonstrate that the 2 rays of lights are not simultaneous because they're not.
Are you taking physics? Or are you just reading things at random? Of course light speed is still c. "Closing speed" is the combined speed of TWO systems, the observer and the lightwave front. The closing speed is c+v for the incoming front and c-v for the front that "chases" the observer.
The incoming fron meets the observer after the time T1;
c*T1+v*T1=L , therefore T1=L/(c+v)
The chasing wavefront catches the observer after T2:
L+v*T2=c*T2 , therefore T2=L/(c-v)
You can see that T2>T1.
This problem has very little do do with relativity except the fact that light always travels at c.
Simple argument for the relativity of simultaneity
You may find it helpful to read the discussion in this thread: https://www.physicsforums.com/showthread.php?t=121068
kknull, are you Swedish? In that case, you've got a spectacular name...
Is it pronounced caca-null?
i'm not swedish. KKnull is referred to the japanese noise artist.
no, i don't think so. Maybe you're referring to the emperor of Austria in the '800, but "kk" are initials of a name, so they can be pronounced as will
kknull said:
hello,
This is false. Yes, they both travel at c. No they don't meet at the same time.
That depends! If they were emitted at the same time according to the observer then they will reach him/her at the same time.
One has to be very careful with statements like this.
Patrick
kknull said:
hello,
This looks to me like the frame of reference of the sources
mmm, the point is that I'm very confused on the concept of relativistic simultaneity, I'm going to read something about it...
Ok. In Swedish it's an abreviation for having sex with a friend...:wink:
  • · Replies 57 ·
  • · Replies 35 ·
  • · Replies 32 ·
  • · Replies 34 ·
  • · Replies 17 ·
  • · Replies 26 ·
  • · Replies 20 ·
  • · Replies 17 ·
