Water friction in pipes, hot vs cold?
The discussion focuses on the friction loss of tap water in pipes at different temperatures, specifically comparing 5 degrees Celsius and 80 degrees Celsius. The average friction loss is noted as 2 kPa, with a minimal change in density (3%) and a significant increase in viscosity (factor of 4) at higher temperatures. The friction factor for smooth pipes is calculated to be approximately 0.01 at 5 degrees Celsius and 0.012 at 80 degrees Celsius, indicating negligible differences in practical applications. Quick calculations adjusting for density and viscosity are recommended for precise assessments.
  • Understanding of fluid dynamics principles
  • Knowledge of viscosity and density concepts
  • Familiarity with Reynolds number calculations
  • Experience with pipe flow analysis
  • Research the impact of temperature on fluid viscosity using the Arrhenius equation
  • Explore advanced fluid dynamics simulations with software like ANSYS Fluent
  • Learn about the Darcy-Weisbach equation for calculating friction loss in pipes
  • Investigate the effects of pipe material and surface roughness on friction factors
Engineers, fluid mechanics students, and professionals involved in plumbing design or hydraulic systems will benefit from this discussion on water friction in pipes at varying temperatures.
TSN79
I usually use an average number of 2 kPa friction loss for normal tap water in pipes. Does anyone know if this number changes significantly up or down for water which is around 80 degrees C instead of 5?
Well, you're looking at only a 3% change in density but a factor of 4 change in the viscosity. Looking at Reynolds numbers (with a constant velocity and ID), this results in a very similar friction factor. I get about .01 vs. .012 for a smooth pipe. I didn't really go any further with the numbers. It looks though like you're not going to see anything noticible. You might do a couple of quick calcs adjusting your density and viscosity to match the two temps.
  • · Replies 31 ·
  • · Replies 20 ·
12K
