How Do You Simplify and Solve Logarithmic Equations?
  • Thread starter Thread starter vijay123
    Logarithms
The discussion revolves around simplifying and solving a logarithmic equation involving the variable \( x \) and logarithmic properties. Participants are exploring the manipulation of logarithmic expressions and the implications of different interpretations of the equation.
  • Participants discuss the simplification of the expression \((\log x / \log 4)^2\) and its relationship to \(\log x^5 / \log 4\). There are attempts to clarify the structure of the equation and its components, with some questioning whether it is linear or quadratic.
There is an ongoing exploration of different interpretations of the equation, with some participants suggesting simplifications and others questioning the nature of the equation (linear vs. quadratic). Guidance has been offered regarding the use of logarithmic properties, but no consensus has been reached.
Participants are navigating potential misunderstandings regarding the equation's structure, particularly concerning the presence of the constant term -4 and the interpretation of logarithmic identities. There is also mention of the complexity of the work involved in showing steps.
vijay123
1) ((logx)/(log4))^2=((logx^5)/(log4))-4
how do you these problmes...i mean..is there anyway of simplfing the expression ...i am stuck..
regards
vijay
Use the fact [itex]\log {a^b} = b\log{a}[/itex] and simplify.
yea...i used it...but this sum is different..seriously..try it
Can you show your work?
mr neutrino...
i can show my work but it is too long...
i ll jus ask you a simple question...
what is (logx/log4)^2...i mean...how do you simplyfy it in terms of logx^5/log4?
First, write your equation as:
[tex](\frac{\log(x)}{\log(4)})^{2}=(\frac{\log(4)}{\log(x^{5})})^{4}[/tex]
Then, collect the terms on the LHS and rewrite your equation as:
[tex](\frac{\log(x)}{\log(4)}-(\frac{\log(4)}{\log(x^{5})})^{2})*(\frac{\log(x)}{\log(4)}+(\frac{\log(4)}{\log(x^{5})})^{2})=0[/tex]
Now, you should be able to continue a bit!
Actually you've got to simplify the second term (logx^5/log4) using the rule I mentioned earlier, and then see if the resulting equation resembles something you've come across before. Remember that log4 is just a constant; don't worry too much about that part.
I believe it was a -4 at the end, and not a power, unless it was a typo.
That minus sign was removed by flipping the fraction. :smile:
EDIT:
Oh dear, it was MINUS 4 not that the exponent was minus 4 as I thought..:cry:
Exactly. :)
Can this be solved analytically?
Of course.
It is a linear equation in the variable log(x).
arildno said:
Of course.
Not quadratic?
neutrino said:
Not quadratic?
It might be..:rolleyes:
Assuming this is
[tex]\left(\frac{log x}{log 4}\right)^2= \frac{log x^5}{log 4}- 4[/tex]
and not
[tex]\left(\frac{log x}{log 4}\right)= \left(\frac{log x^5}{log 4}\right)^{- 4}[/tex]
as I also initially interpreted it, let y= log x. since log x5= 5 log x, this can be written as
[tex]\frac{1}{(log 4)^2}y^2- \frac{5}{log 4} y+ 4= 0[/tex]
a quadratic equation for y.
("log 4" is, of course, simply a constant.)
11K
