Mass and Speed: The Relationship in Relativity
The discussion centers on the relationship between mass and speed in the context of relativity, exploring concepts such as relativistic mass, rest mass, and the implications of different frames of reference. Participants examine how mass is perceived as objects approach the speed of light and the effects of motion relative to Earth.
  • Some participants propose that mass increases as one approaches the speed of light, questioning whether the maximum value is infinity or dependent on rest mass.
  • Others argue that mass does not increase in the local frame of reference, suggesting that it is a property of relativistic momentum instead.
  • A mathematical expression for calculating relativistic mass is provided: m = γm₀, where γ = 1/√(1 - v²/c²), with v being the object's velocity and c the speed of light.
  • Some participants discuss the implications of Earth's rotation on perceived mass, suggesting that motion relative to Earth affects the observed mass of objects.
  • There is a distinction made between "relativistic mass" and "rest mass," with some advocating for the use of rest mass to avoid confusion.
  • Participants explore whether the concept of mass should be treated as dynamic, depending on the frame of reference, and whether similar considerations apply to time and distance.
  • One participant mentions that their textbook does not support the idea of increasing mass with velocity, emphasizing that momentum changes with speed instead.
  • There is a discussion about the definitions of mass, including "relativistic mass" and "proper mass," and how these definitions influence the understanding of mass in relativity.
Participants express differing views on whether mass increases with speed, with some asserting that it does and others rejecting this notion in favor of momentum changes. The discussion remains unresolved, with multiple competing views present.
Participants reference various textbooks and interpretations of relativity, indicating that definitions and understandings of mass may vary significantly. There are unresolved assumptions about the implications of Earth's motion and the nature of mass in different frames of reference.
denni89627
mass increased as you approach the speed of light correct? what is the max value- infinity or something else depending on the rest mass? basically what I am getting at is how would you calculate the increase in mass based on speed? plus what is speed, after all this is relativity. speed relative to the Earth which is also rotating in space? would everythig weigh fractionally less if the Earth stopped rotating (without affecting gravity) since you would be in less motion relative to the universe?
Well my understanding of it is that mass does not increase in the local frame of reference (this is sometimes called the rest mass of the object), in fact it decreases if the the energy to accelerate comes from the mass in question (due to [tex]E = Mc^2[/tex]).
However for any other frame of reference that observes a change in distance or direction the mass appears to increase (sometimes called relativistic mass).
Infinity.
[tex] m = \gamma m_0[/tex]
where
[tex] \gamma = \frac{1}{\sqrt{1 - \frac{v^2}{c^2}}}[/tex]
m_0 is the rest mass, v is the velocity of the object, c is the speed of light.
It depends on your frame compared to the object in question. Assume the object is in space, speeding towards the Earth. If you're sitting on the Earth, and the Earth is rotating in a direction so that you are moving towards the speeding object, the object will appear more massive than if the Earth wasn't spinning. If you are moving away from the object due to the Earth's rotation, the object will be less massive.
There is no "relative to the universe." There are no reference points that allow us to fix the universe's position relative to ourselves.
EDIT: Cleared up some confusion.
Really? :confused:
MeJennifer said:
Really? :confused:
I should have specified that the speeding object is moving towards you in the first place...fixed.
In my SR course and textbook (Modern Physics, Tippler & ...Llewyn or something?) the view taken is that mass does not increase as you approach the speed of light, but rather the funny business is a property of relativistic momentum. Of course, if I recall everything correctly, if you measure the mass of an object moving at relativistic speeds, the mass you measure will be the rest mass times (1-(v/c)^2)^(-1/2).
Relativistic mass
Yes, we should refrain from talking about mass that increases with velocity - mass should rather mean 'rest mass' to avoid confusion.
It is coordinate energy and momentum that increase with coordinate velocity, not mass.
Hi,
In this case, should we say that :
"if you measure the duration of a phenomenon moving at relativistic speed, the duration you measure will be the rest duration times (1-(v/c)^2)^(-1/2)"
or
" if you measure the length of an object moving at a relativistic speed, the length you measure will be the rest length divided by (1-(v/c)^2)^(-1/2)"
Thanks
Well I do not see the confusion at all. :smile:
I mean would you prefer to use rest elapsed time and rest distance as well because if might confuse?
There is no confusion if we accept that elapsed time, distance and mass are dynamic properties and that their values depend on the frame of reference.
But there are no things like "rest elapsed time and rest distance". There are coordinates distances and times and there is a thing like rest mass.
Would you assign a dynamic mass to a photon too?
Whether mass depends on velocity depends on the definition of "mass." There are two common meanings of the term "mass" as widely used in relativity. One is called "relativistic mass" defined as m = p/v and one is "proper mass" defined as the magnitude of the particle's 4-momentum. Relativistic mass is the velocity dependent one. Proper mass is the velocity dependent mass.
Pete
Pete
Yes, you can view things like that; what I was saying is that my textbook chooses the viewpoint where there is no relativistic mass - it's momentum that changes nonlinearly with speed:
p = [(1-(v/c)²)^-½]mv, where m is the invariant mass
i.e., the factor (1-(v/c)²)^½ acts on the classical (non-relativistic) momentum, not the mass. Thus, mass remains an invariant property of a system, independent of the frame of reference - it's momentum whose value depends on the frame of reference in which it is measured.
Of course, the choice is kind of arbitrary, but perhaps more aesthetically pleasing to some.
What's the name and author of your text?
Yes. I'm aware of these things. Thanks. For a detailed description you can read a web page I created on what you're speaking of. See
http://www.geocities.com/physics_world/sr/invariant_mass.htm
Pete
The book is "Modern Physics", 4th edition, by Tippler and Llewellyn.
The exact phrasing on the matter is:
"The quantity m(u) [=m/(1-(v/c)²)^½] in equation 2-5 is sometimes called the relativistic mass; however, we shall avoid using the term or a symbol for relativistic mass: in this book, m always refers to the mass measured in the rest frame. In this we are following Einstein's view. In a letter to a colleague in 1948 he wrote:
It is not good to introduce the concept of M=m/(1-(v/c)²)^½] of a body for which no clear definition can be given. It is bnetter to introduce no other mass than "the rest mass" m. Instead of introducing M, it is better to mention the expression for the momentum and energy of a body in motion."
--page 72 in the book
Pete
There are a couple of minor errors in the "Invariant mass of a single particle" section: you accidentally write m = γm[0]c², and you state "the magnitude of U, is c². I.e. U·U = c²" when of course |U| = (U·U)^½, so |U| should be c.
Actually if one wishes to be "in keeping" with Einstein one must use relativistic mass with v = 0. In general this is not the proper mass of the particle. When there is a gravitational field present gamma does not equal 1 when v = 0. Einstein used this in his relativity text in regards to Mach's Principle and the relationship between the gravitational field and the particle's inertial mass.
Thanks for the corrections to my web page.:smile:
Pete
A simple answer to the original question using a double engine steam train. You drag a carriage full of coal to burn to go faster and the coal carriage is part of your train, a closed system. The first trip you only use the one engine and hit 100mph and your coal just runs out as you enter the last station. You want to go even faster on the return trip, say up to 150, so you must fire up the second engine, but need an additional coal carriage to feed it to get all the way to you destination. More speed equals more weight in the system and to push on to 180mph you would need another engine and coal carriage...etc.
What ever your mode of transport and energy source to drive it you always end up in a deminishing returns situation when you want to go faster.
  • · Replies 25 ·
  • · Replies 64 ·
13K
  • · Replies 25 ·
  • · Replies 45 ·
  • · Replies 130 ·
18K
