How do I solve an AP chem free response on ammonia and light interactions?
  • Thread starter Thread starter doremi
    Ap Chem Response
The discussion revolves around solving a series of AP Chemistry free response questions related to ammonia and its interactions with light, as well as a reaction involving nitrogen monoxide and bromine. The scope includes equilibrium expressions, pH calculations, reaction rates, and electronic transitions in atoms.
  • Homework-related
  • One participant requests help with writing the equilibrium-constant expression for the ammonia reaction and calculating the pH, base ionization constant, and percent ionization.
  • Another participant proposes a rate law for the reaction between NO and Br2, suggesting that the order of reaction with respect to Br2 is 1 based on experimental data.
  • Further calculations are suggested for determining the order of reaction with respect to NO, indicating that it may be 2 based on the provided rates from experiments.
  • Participants discuss the calculations related to light interactions, including frequency and energy of photons, and the implications of electronic transitions in hydrogen and helium ions.
  • One participant mentions the relationship between energy levels in hydrogen and helium ions, noting the influence of nuclear charge on energy calculations.
Participants express varying degrees of confidence in their calculations and reasoning, with some proposing methods and others questioning or refining those methods. No consensus is reached on all aspects of the problems, particularly regarding the calculations and interpretations of the results.
Some calculations depend on assumptions about constant temperature and concentration, and there are unresolved details regarding specific values and constants used in the calculations.
Students preparing for AP Chemistry exams, educators looking for examples of problem-solving in chemistry, and individuals interested in chemical kinetics and equilibrium concepts.
doremi
[SOLVED] an AP chem free response (please help!)
i have a final tomorrow (yea i was procrasinating) and i have to figure out how to do these practice problems! please help you can! i need to know how to do it ASAP!
NH3(aq) + H20(l) <---> NH4+(aq) + OH-(aq)
In aqueous solution, ammonia reacts as represented above. In 0.0180M NH3(aq) at 25C, the hydroxide ion concentration, [OH-], is 5.60x10^-4M. In answering the following, assume that temperature is constant at 25C and that volumes are additive.
a) Write the equilibrium-constant expression for the reaction represented above.
b) Determine the pH of 0.0180M NH3(aq).
c) Determine the value of the base ionization constant, Kb, for NH3(aq).
d) Determine the percent ionization of NH3 in 0.0180M NH3 (aq).
e) In an experiment, a 20.0 mL sample of 0.0180M NH3 (aq) was placed in a flask and titrated to the equivalence point and beyond using 0.0120 M Hcl(aq).
i) Determine the volume of 0.0120 M HCl (aq) that was added to reach the equivalence point.
ii) Determine the pH of the solution in the flask after a total of 15.0mL of 0.0120 M Hcl(aq) was added.
iii) Determine the pH of the solutiobn in the flask after a total of 40.0mL of 0.0120M Hcl(aq) was added.
Answer the following questions regarding light and its interactions with molecules, atoms, and ions.
a) The longest wavelength of light with enough energy to brea the cl-cl bond in cl2(g) is 495nm.
i)Calculate the frequency, in s^-1, of the light.
ii) Calculate the energy, in J, of a photon of the light.
iii) Calculate the minimum energy, in kJ mol^-1, of the Cl-Cl bond.
b) A certain line in the spectrum of atomic hydrogen is associated with electronic transition in the H atom from the sixth energy level (n=6) to the second energy level (n=2).
i) Indicate whether the H atom emits energy or whether it absorbs energy during the trasition. Justify your answer.
ii) Calculate the wavelength, in nm, of the radiation associated with the spectral line.
iii) Account for the observation that the amount of energy associated with the same elctronic transition (n=6 to n=2) in the He+ ion is greater than that associated with the corresponding transition in the H atom.
and this is the second problems
2NO(g) + Br2(g) ---> 2NOBr(g)
A rate study of the reaction represented was conducted at 25C. The data that were obtained are shown in the table below.
Experiment Initial [NO] Initial [Br2] Initial Rate of Appearance
(mol L^-1) (mol L^-1) of NOBr (mol L^-1s^-1)
1 0.0160 0.0120 3.24x10^-4
2 0.0160 0.0240 6.38x10^-4
3 0.0320 0.0060 6.42x10^-4
a) Calculate the initial rate of dissapearance of Br2(g) in experiment 1.
b) Determine the order of the reaction with respect to each reactant, Br2(g) and NO(g). In each case, explain your resoning.
c) For the reaction,
i) Write the rate law that is consitent with the data, and
ii) calculate the value of the specific rate constant k, and specify units.
d) the following mechanism was proposed for the reaction:
Br2(g)+NO(g) ---> NOBr2(g) slow
NOBr2(g) + NO(g) ---> 2NOBr(g) fast
In this mechanism consitent with the given experimental observations? Justify your answer.
For Question No 3
[tex]Rate=k[NO]^m[Br_2]^n[/tex]
where m and n are order of reaction w.r.t [NO]&[Br2]
Code:
Experiment   Initial[NO]    Initial[Br2]    Initial Rate of Appearance
so u see from the above equation u see if conc of NO remains constant on doubling the conc of bromine we see the rate doubles hence
[tex]2^n=2[/tex]
therefore n=1
Similarly for EXP 3 u have Rate=6.42*10^-4
and rate for EXP 1 =3.24*10^-4
divide Rate for Exp 3 by Exp 1 u get
[tex]2^m*2^{-1}=2[/tex]
so m=2
I forget to welcome u and i want to direct you to sticky https://www.physicsforums.com/showthread.php?s=&threadid=28
Though above post is a clear solution still i give u some hints
initial Rate of disappearance of Br2= initial rate of appearance of NOBr
[tex]-\frac{d[NO]}{2dt}=-\frac{d[Br_2]}{dt}=\frac{d[NOBr]}{dt}[/tex]
I hope u will caluate it for part c
i) [tex]f=\frac{c}{\lambda} \mbox{where c is speed of light }[/tex]
ii) E=hf where h planks constant
iii) [tex]E_{min}=\frac{hc}{\lambda}=hf[/tex]
B)
It will emit a photon or Energy
[tex]E_n=-\frac{-13.6eV}{n^2}[/tex] ... for Hydrogen atom
[tex]E_6-E_2=\frac{hc}{\lambda}[/tex]
Since energy is due to Electrostatics interaction And we observe that The nuclei of helium have different no. of Protons than that of hydrogen so the above energy equation has a factor of Z^2 in addition
njkvbj,m
himanshu121 said:
B)
Is this from the equation:
[tex]E_n=-\frac{Cz^2}{n^2}[/tex]
I was taught this last year, the prof didnt tell us the value of C for hydrogenic atoms though :<
10K
