Can Absolute Zero Help Us Understand the Nature of Time?
The discussion centers around the relationship between absolute zero and the nature of time, exploring whether the cessation of movement at absolute zero could provide insights into time manipulation or the concept of time itself. Participants engage with theoretical implications, definitions of time, and the effects of temperature on time perception.
  • Theoretical
  • Some participants propose that time is fundamentally linked to movement, suggesting that if movement ceases at absolute zero, then time also ceases in that context.
  • Others argue that time is independent of movement, asserting that time continues to pass regardless of whether an object is in motion or at rest.
  • One participant mentions time dilation, indicating that if all movement ceases, time could be perceived as infinitely dilated or "stopped," but this remains a contested viewpoint.
  • There is a discussion about the implications of absolute zero being unreachable, with some suggesting that this limits the relevance of the discussion on time manipulation or time travel.
  • Some participants highlight that dynamics do not cease at absolute zero, referencing quantum states of particles that still exist in a minimum energy state.
  • A few contributions suggest that the relationship between time and entropy is significant, questioning whether entropy is necessary for time to exist.
  • There are mentions of the observer-dependent nature of time, with discussions on how different frames of reference affect the perception of time passing.
Participants express multiple competing views on the relationship between movement and time, with no consensus reached. The discussion remains unresolved regarding the implications of absolute zero on the nature of time.
Limitations include the unresolved nature of the relationship between time and movement, the dependence on definitions of time and entropy, and the theoretical status of absolute zero as an unattainable state.
JSK333
Hello,
I think of time simply as movement or distance traveled. No movement = no time.
Going with such a concept, could the inability to reach absolute zero explain our inability to manipulate time?
If at absolute zero, movement ceases, then time would also cease for that area.
What are your thoughts on this connection?
I know of no physical principles which say that time is dependent upon movement. We know that if something moves time must be passing, but that does not mean that if something does not move time does not pass.
If nothing moves, including electrons, protons, neutrons, then nothing changes--no aging, no degradation, etc. When nothing changes we have no awareness of timing passing.
At absolute zero, nothing moves/changes, correct? All activity stops.
What do others think about this connection?
As Integral said, there is no connection between movement and time. You are free to choose your coordinate system such that some object is at rest in it. In other words, you're always free to consider any object you wish to be absolutely at rest. Time, however, still marches on.
- Warren
I tend to dissagree. When we speak of time dilation, we mean the slowing of movement, provided that slowing is homogenous. If all movement ceases completely, then it can be said that time has infinitely dilated, or "stopped".
Or if one takes the thermodynamacist's definition of time, it is considered the increase of entropy. But again, if all movement ceases, entropy can no longer increase, so time must still be seen as "stopped".
The definition of time dilation makes no reference to movement at all.
The bottom line is this: I have a baseball. I can define a frame of reference such that in it the baseball is at rest. I will assign the baseball the spatial coordinates (0, 0, 0). The time coordinate is unaffected by my choice of spatial coordinates.
The definition of 'rest' is a relativistic one, and requires the definition of an observer. The baseball may be at rest with respect to me, and not be at rest with respect to you. Does that mean that time stops for the object, or not? You're sitting in a chair right now. Your butt and the chair are at rest. Do your butt and chair experience no time?
- Warren
The definition of 'rest' is a relativistic one, and requires the defintion of an observer. The baseball may be at rest with respect to me, and not be at rest with respect to you. Does that mean that time stops for the object, or not? You're sitting in a chair right now. Your butt and the chair are at rest. Do your butt and chair experience no time?
- Warren
You aren't thinking it through as much as I have.
A chair is not a fundamental particle. It is made up of particles that are moving. Even if the "chair" is not moving, what makes it up is.
If each one was stopped, it would be at absolute zero, and there would be no movement. It would not age/degrade, because nothing is happening; i.e., no time.
Do you see what I mean now? Even what we think of being "at rest" is not truly at rest, because of its more fundamental makeup.
On the contrary, I've probably thought about it much more than you.
It doesn't matter whether the particle is fundamental or composite. You can just as well declare a frame of reference within which your favorite subatomic particle is at rest (or, at least, the peak of its wavefunction is).
Besides, it's a completely moot point. Absolute zero is not reachable, so it doesn't really matter what would or would not happen there -- it's not definable. I'm tempted to put this thread in Theory Development at this point.
- Warren
- Warren
This is the main reason why I posted this, as I mentioned in the first post.
Since we are not able to reach AZ, could this also be why no one has been able to achieve time travel and/or a complete stasis field?
Question: why is AZ not reachable?
Time travel? Statis field? Off it goes.
- Warren
- Warren
I mentioned manipulation of time in my first post.
Sorry if I chose the wrong forum. I thought Absolute Zero as the main subject would put it here.
Dynamics do not cease at absolute zero. For instance, spin-1/2 particles are in a nonzero minimum energy state there.
the definition of time
Jsk33, your thoughts are very close to mine, but you should start to find a mathematical prove that time is dependent from energy and events.
I think this topic has to do with theory of groups and symmetry operations. For example, for the molecules in difusive movement, there´s no distinction between past and future. In my opinion, the only thing that can break this symmetry are referential events (so they could be used as a clock).
In absolute zero, there´s and even stronger simmetry. All operations are simmetrycal. You can´t say if time is moving or if it is stoped. The arrow of time disappear and time becomes an arbitrary variable.
Question: is entropy necessary for time to exist?
It's true that in a referencesystem that's warm...
time passes slower...
and in a refferencesystem that's cold time passes faster.
but Dxobject within the referencesystem is 0 when T=O
But T is never 0 because of Heisenbergs relation.
And
Dx2passing + Dx2object is always c2t2.
So you are saying that if the average particle velocity v=(kT/m)1/2 (by Boltzmann) due to temperature is reduced, so is the passage of time? No wonder food keeps better in the refrigerator!
Remember though, that time is observer-dependent, so I guess if both the observer and object systems were composed of spin-zero particles at absolute zero, time might stop. Brrrrrr!
(By definition, observer-object interaction must actually involve both bosons and fermions.)
Originally posted by Loren Booda
DELTA = V
Let's say you made a neutrino stopp moving.
First off all, you would need to stopp it from moving h/(m4(pi)Vx) meters per second IN EVERY INSTANCE. The acceleration you would need to slow it down to let's say 0.5 m/s would make it grow more than 10 times it's own weight.
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 40 ·
17K
  • · Replies 26 ·
11K
