Sulfur Extraction and Potassium Nitrate
  • Thread starter Thread starter fireboytommy
    Extraction sulfur
This discussion focuses on the extraction of Potassium Nitrate from nitrate-bearing materials and the sourcing of elemental Sulfur. The user inquires about extracting Potassium Nitrate from two sources: potting soil with 0.09% nitrate nitrogen and gravel containing 9.00% nitrogen nitrate, with a recipe from Jolly Roger suggesting boiling water and ash. Additionally, the user seeks a method to extract Sulfur from Epsom salt but is advised that it is impractical and should instead consider purchasing "Hi-Yield Dusting Wettable Sulfur," which contains 90% pure Sulfur, commonly used for pest control.
  • Understanding of chemical extraction processes
  • Familiarity with Potassium Nitrate and its applications
  • Knowledge of Sulfur sources and their purity levels
  • Basic safety protocols for handling chemicals
  • Research the chemical properties and extraction methods for Potassium Nitrate
  • Investigate the use of "Hi-Yield Dusting Wettable Sulfur" for pest control
  • Explore safe methods for handling and experimenting with pyrotechnics
  • Learn about alternative sources of elemental Sulfur and their extraction
This discussion is beneficial for hobbyists in pyrotechnics, chemists interested in chemical extraction, and gardeners seeking effective pest control solutions using Sulfur.
fireboytommy
Well I've found this recipe to extract Potassium Nitrate from nitrate bearing potting soil containing 0.09% nitrate nitrogen and I've also found this one soil (well its more like rocky gravel) for turfs that contains 9.00% nitrogen nitrate. Okay so my question is can i extract the one with 9.00% when its in gravel type form with boiling water and ash on the bottom of it like the recipe says or should i just stick with the potting soil. Also i saw that the 9.00% percent one is from ammonium nitrate.
Oh yeah the recipe is from jolly roger i know its not safe but what the heck its not nitroglycerin.
I've also been looking for sulfur. I was wondering if it was possible to extract it from epsom salt (magnesium sulfate) but i was thinking that was pretty hard and i should stick to going to nurserys or pharmacies (despite the fact that at pharmacies you have to have a damn good explanation to tell them why you need it) and well yeah. i was wondering if i could get sulfur (90% pure or more in crystalline/powder form) from household ingredients using a safe procedure...well...dont worry abou thte safety too much... :)
Thansk i would really appreciate the help I am just trying to experiment with a little bit of gunpowder in pyrotechnics.
Chemistry news on Phys.org
As for the Sulfur,
It will be way too difficult to try to extract elemental Sulfur from Magnesium Sulfate...best to find another source.
I get sulfur at a garden[-ish] type of store, brand name "Hi-Yield Dusting Wettable Sulfur". It comes in a 4 lb. yellow and red, heavy duty paper bag containing 90% pure Sulfur. I believe it is often used (or is supposed to be used as) repel certain pests (like chiggers and mites) on plants.
Something like this would probably be your best option.
  • · Replies 19 ·
11K
