Solving Video Movie Problem: Winamp Issues
  • Thread starter Thread starter peejake
    Movie Video
The discussion revolves around a technical issue related to playing an AVI video file in Winamp on a laptop, where the audio plays but the video does not display. Participants explore potential causes and solutions, including codec issues and software recommendations.
  • One participant suggests that the issue may be due to missing codecs on the laptop, as the AVI format can vary in structure.
  • Another participant mentions that Winamp might not be able to download the necessary codec if the laptop is not connected to the internet.
  • It is proposed that a corrupted codec or a bad file transfer could also be potential causes of the problem.
  • A recommendation is made to use ffdshow, a directshow decoding filter, which can handle many codecs and is favored by videophiles for real-time video manipulation.
  • Another participant suggests using GSpot codec appliance to identify missing codecs.
  • One participant expresses that after installing ffdshow, the video played well in Winamp, although they noticed some degradation in video quality.
Participants generally agree on the potential codec issue and the usefulness of ffdshow, but there is no consensus on the necessity of changing the video format or the impact of quality degradation.
Some assumptions about codec availability and file integrity are present, but these remain unresolved. The discussion does not clarify the extent of the quality degradation experienced by the participant.
peejake
hey guys,
Here is the problem...i downloaded a video in avi. format...I played it in winamp and it worked well...Then i transferred it to my laptop and tried to play it in winamp and all that happens is that i can hear the sound and see no video...whats happening? All other videos work well...
Thanks
Jake
Computer science news on Phys.org
Most likely cause is you are missing the particular codec on the laptop that the file need.
The .avi designator is kind of a catch all. The actual stucture of the file can vary.
When a pgm opens the file it looks at the file header to determine which codec to load to decode the video.
Audio is a separate codec and you can have the reverse happen. You see the video with no sound.
I'm going to guess that you don't have the laptop on the net. If you did then winamp might try to donwload the right codec.
You could also have a corupted codec or the file transfer went bad.
A good directshow decoding filter which has the ability to play many codecs is ffdshow. It works in the backgound for practically all media players.
Ffdshow is used by many videophiles because you can manipulate the video real time.
You can download it from sourceforge.
Wikipedia:http://en.wikipedia.org/wiki/Ffdshow"
Thankyou all for the help,
Ill download Ffdshow and try to change the format of the video and see if it helps...
Jake
Jake
No need to change the format, once you installed ffdshow the video should play just fine in whatever player you use.
If it still does not play then if you like and it is "for all eyes" you could post it on one of those free internet spaces and I will take a look at it. :smile:
you could also download gspot codec appliance to find out which codec your missing and get it
You are right...I downloaded the program and installed. After that i just used winamp that i used to use and it worked pretty well..:smile: I am glad it did. HOwever i discovered that there was a little degrading of the actual quality of the video, which does not bother me much...It works and I am happy:smile:
Thankyou MeJennifer and everybody else who has helped me...:smile:
  • · Replies 35 ·
  • · Replies 23 ·
