Absolute Motion: Can Wristwatches Prove It?
  • Context: Graduate
  • Thread starter Thread starter actionintegral
    Absolute Motion
The discussion revolves around the concept of absolute motion and the implications of wristwatch synchronization in different frames of reference. Participants explore the effects of relative motion on time perception, particularly in the context of special relativity, and the synchronization of clocks in moving and stationary frames.
  • One participant describes a scenario where two lines of synchronized wristwatches begin to move, questioning how the time on their watches would compare after reaching a constant velocity.
  • Another participant suggests that during acceleration, the moving line perceives the other line's time as speeding up, while the stationary line sees the moving line's time as slowing down.
  • A different participant emphasizes their interest in the time comparison only after both lines have reached a constant velocity, dismissing the acceleration phase as irrelevant.
  • Some participants argue that both observers will measure each other's elapsed time as slower due to their relative motion, but they will agree on the elapsed time when they meet.
  • One participant expresses confusion over the implications of time dilation and questions whether anyone actually ages differently based on their paths through spacetime.
  • Another participant clarifies that while clocks may appear to run slower from a relative perspective, this does not mean they actually do; rather, it is a result of the paths taken through spacetime.
  • Participants discuss the Einstein synchronization method and its implications for simultaneity in moving frames, highlighting the ambiguity in defining simultaneous events when motion is involved.
Participants exhibit disagreement regarding the interpretation of time dilation and simultaneity in different frames of reference. Some assert that clocks do not actually slow down, while others maintain that perceived time differences arise from relative motion. The discussion remains unresolved with multiple competing views present.
The discussion includes various assumptions about synchronization methods and the nature of time in relativity, which may not be universally accepted. The implications of acceleration on simultaneity and the interpretation of time measurements are also points of contention.
actionintegral
In another thread, born2perform asked an interesting question. I would like to re-ask that question in the most concise way I know how.
I stand ,at rest, shoulder-to-shoulder with other observers in an infinitely long line.Our wristwatches are all syncronized.
My line faces another line of observers, also at rest, wristwatches syncronized.
So everybody is at rest and and all wristwatches are syncronized.
My group simultaneously begins moving to the right with some velocity.
I look the wristwatches of the people who pass by me. How will the time on their wristwatches compare to the time on my wristwatch?
They answered me something like this:
since the sistem is not linear, in order that you must accelerate to gain speed, your moving line sees the other line's time speed up, at least during the acceleration; and that line sees your time slow down.
If your line is alredy in move, each one sees the other's time slow down, until the symmetry is broken, respecting the relativity principle.
but i think the usual problem is this: how do you synchronize the two lines? at least pervect said that in the previous thread, as i understood
Thank you for your reply. However, I am not interested in the short period of time during which my line is accelerating. I am interested in the period of time after we have all reached given final velocity and we are all coasting along.
It has nothing to do with some symmetry being broken or so. Both people's elapsed time will be the same when the meet, it is simply measured to go slower from the other frame of reference.
Many people seem to have a particular problem with time. For instance this issue rarely comes up with length.
Both see the other's length in the direction of travel shorter, but in fact none of them gets any shorter.
in 10 lines you have upsetted all i learned about relativity :eek:
"Both see the other's length in the direction of travel shorter, but in fact none of them gets any shorter"
"Both people's elapsed time will be the same when the meet"
so you are saying that nobody gets younger than the other??
What happens:
As soon as you start moving to the right, you re-check the synchronization on your writwatches, and find that they are no longer synchronized.
How do you synchronize watches? You use the Einstein convention - you put a light source at the midpoint of the watches to synchronize, and because the speed of light is constant, you know that light hits the two clocks to be synchronized "at the same time".The following space-time diagram might help
[tex] \]<br /> <br /> \unitlength 1mm<br /> \begin{picture}(60,90)(0,0)<br /> \linethickness{0.3mm}<br /> \put(10,10){\line(0,1){80}}<br /> \linethickness{0.3mm}<br /> \put(20,10){\line(0,1){80}}<br /> \linethickness{0.3mm}<br /> \put(30,10){\line(0,1){80}}<br /> \linethickness{0.3mm}<br /> \put(40,10){\line(0,1){80}}<br /> \linethickness{0.3mm}<br /> \put(50,10){\line(0,1){80}}<br /> \linethickness{0.3mm}<br /> \put(60,10){\line(0,1){80}}<br /> \linethickness{0.3mm}<br /> \put(15,10){\line(0,1){20}}<br /> \linethickness{0.3mm}<br /> \multiput(15,30)(0.12,0.24){250}{\line(0,1){0.24}}<br /> \linethickness{0.3mm}<br /> \put(25,10){\line(0,1){20}}<br /> \linethickness{0.3mm}<br /> \multiput(25,30)(0.12,0.24){250}{\line(0,1){0.24}}<br /> {\color{red}<br /> \linethickness{0.3mm}<br /> \multiput(10,22.5)(0.24,0.12){208}{\line(1,0){0.24}}<br /> \linethickness{0.3mm}<br /> \multiput(10,27.5)(0.24,0.12){208}{\line(1,0){0.24}}<br /> }<br /> {\color{blue}<br /> \linethickness{0.3mm}<br /> \put(10,15){\line(1,0){50}}<br /> \linethickness{0.3mm}<br /> \put(10,20){\line(1,0){50}}<br /> }<br /> \end{picture}<br /> <br /> \[[/tex]
Vertical lines are the clocks that "stay still".
The lines that start out vertical and bend represent the lines that start moving.
The blue lines represent events that are simultaneous in the "non-moving" frame.
The red lines represent events that are simultaneous in the "moving" frame.
As you can see, the idea of your line "simultaneously" starting to move is ambiguous. Which notion of simultaneity do you use, the notion "before" you started moving, or the notion "after"? The diagram is drawn using the "before" notion.
There is a simple law for the "line of simultaneity" - if you are moving at a velocity v, the slope of the line of simultaneity is c^2 / v.
Thus the product of the slope of a line and the slope of the line of simultaneity is always c^2. This is most conveneint when c=1, then the product is always 1.
This rule can be derived from the Lorentz transform.
Well for sure nobody is getting younger, that is a fact. :smile:
Now if traveler A travels on a path in space-time that is longer than that of person B (which will happen if he accelerates) and then when they meet later it will the case that the elapsed time for A is less than B so he will actually have aged less.
But that does not mean that his clock went slower, clocks don't slow down due to relativity! What it means is that he took a longer path in space-time with a result that less time was spent compared to the time spent for person B. If you were to accelerate almost instantly to almost light speed and then for us after a year you would come back then for you almost no time has elapsed.
So we are talking about two different things here. Relativistic measurements (clocks slowing down, lengths contracting, masses increasing) and paths in space-time. For the twin experiment the essense is the paths in space-time not the relativistic measurements.
So I think it is important to remember the following things in relativity:
  • Clocks never slow down
  • Masses never increase
  • Lengths never contract
  • Each object can have its own age due to the paths it took in space-time
  • Clocks seem to go slower, lengths seem shortened and masses seem increased if measured in relative motion to us.
Excellent. So a delta-v will cause us to lose simultaneity.
Yep. I've been busy editing my diagram to make it look better and cleaning up the text - you might take another look at it.
Here's another diagram, showing in more detail how the Einstein synchronization method yields the results I mentioned previously.
The slanted lines are all moving clocks. The "middle" moving clock (middle slanted line) emits a light pulse, which arives "at the same time" at the other two clocks (slanted lines). Therfore, the red line through the two points at which the light pulses hit the inner and outer slanted lines must represent the moving frames notion of "simultaneous events" - as long as the distance between the middle clock and each of the outer clocks is the same (which it is in this diagram).
The light beams in this diagram are all drawn to scale at a 1:1 slope, i.e. at 45 degrees.
[tex] \]<br /> \unitlength 1mm<br /> \begin{picture}(90,80)(0,0)<br /> \linethickness{0.3mm}<br /> \multiput(20,20)(0.12,0.24){250}{\line(0,1){0.24}}<br /> \linethickness{0.3mm}<br /> \multiput(40,20)(0.12,0.24){250}{\line(0,1){0.24}}<br /> \linethickness{0.3mm}<br /> \multiput(60,20)(0.12,0.24){250}{\line(0,1){0.24}}<br /> \linethickness{0.3mm}<br /> \multiput(40,20)(0.12,0.12){333}{\line(1,0){0.12}}<br /> \put(80,60){\vector(1,1){0.12}}<br /> \linethickness{0.3mm}<br /> \multiput(26.88,33.12)(0.12,-0.12){109}{\line(1,0){0.12}}<br /> \put(26.88,33.12){\vector(-1,1){0.12}}<br /> {\color{red}<br /> \linethickness{0.3mm}<br /> \multiput(10,25)(0.24,0.12){333}{\line(1,0){0.24}}<br /> }<br /> \end{picture}<br /> \[[/tex]
Note that the Einstein clock synchronization method is equivalent to "slow clock transport" in relativity, and is the only synchronization scheme that allows rapidities to be proportional to velocities.
I'm going to digress a bit, and attempt to motivate Einstein clock synchronization a bit more - i.e explain why it is a good idea, and other schemes for synchronizing clocks are not good (unless they are equivalent).
A velocity measurement requires two syncronized clocks - a rapidity measurement only requires one clock, on the moving object itself.
To measure velocity, one synchronizes the clocks at the start and end of the "course". One then measures the time at which the object crosses the "starting line", subtracts it from the time that the object arives at the "finish line" and defines the velocity as the distance between the start and finish lines divided by the elapsed time.
To measure rapidity, one uses one clock on the object itself. One notes the time at which the clock crosses the starting line, and one notes the time at which the clock crosses the finish line on the same clock.
Rapidities can only be measured for physical objects - one cannot make a clock go at lightspeed.
If clocks are synchronized fairly, one expects rapidities, measured using one clock, to be proportional to velocities, using a "fair" synchronization scheme, as described above.
[add]This wasn't very clearly explained - see later post for more detail and discussion. The issue is really isotropy, not proportionality. Given a set of particles with constant and isotropic rapidity - i.e. the rapidity is independent of direction, we say that an "fair" clock synchronization is one which gives a set of velocities which are also isotropic (independent of direction).
This isotropy is an important motivator of Einstein's theory. In Einstein's original paper, this is just referred to as "isotropy" or "isotropy of space-time". I've always found this a bit murky, hence the longer explanation.
A velocity measurement requires two clocks - a rapidity measurement only requires one clock, on the moving object itself.
If clocks are synchronized fairly, one expects rapidities, measured using one clock, to be proportional to velocities, using a "fair" synchronization scheme. The Einstein scheme is the only one that allows "fair" synchronization that makes rapidity proportional to velocity.
Can you clarify your definition of "rapidity"?
It does not agree with the more common usage as the "Minkowski angle", i.e., the additive-parameter associated with a boost. With this more common definition, in SR, the velocity is not proportional to the rapidity... instead it is proportional to the hyperbolic-tangent of the rapidity.
Rapidity is just distance divided by proper time - which should be equivalent to the Minkowski angle.
I probably have failed to make my point clear, so let me explain at further length what I was attempting to say. (I've also taken the liberty of fixing up my earlier post significantly).
What I'm concerned with is isotropy. Consider an object with a rapidity of 'n' going east-west, where n is some number. Measure its velocity using two synchronized clocks and some suitable clock synchronizaton scheme.
Now measure the velocity of an object with the same value of rapidity, 'n', going west-east. Measure its velocity again, using the same two clocks, and not changing their synchronization for the second measurement.
If the clocks are synchronized fairly, the velocity east-west will be the same as the velocity west-east.
The exact value of the ratio of rapidity / velocity will vary with the rapidity 'n' chosen. But in order to make the ratio of velocity / rapidity isotropic (the same ratio E-W as W-E), one must chose Einstein clock synchronization, or some equivalent.
I think it is also important to remember that the alternative viewpoint is also tenable. That is,
  • The rate at which clocks tick depends on their speed and the gravitational potential
  • Masses depend on speed and gravitational potential
  • Each object can have its own age due to the paths it took in spacetime, but there can also be a universal time.
Carl
Carl
Well I am not sure who makes those claims of tenability, I see several problems with the points listed.
Apart from the fact that speed is relative, it must be clear that the laws of physics cannot depend on the speed of something as Einstein correctly postulated in his theory of relativity. So clocks must run at the same speed in all inertial frames, and all lengths must be the same and masses must also be the same.
It is only the measurements between frames that show differences.
And lastly, the existence of an absolute time is simply inconsistent with Einstein's theory of relativity.
So, I would not consider them tenable at all.
MeJennifer ...I think your post 7 was very well put
  • · Replies 25 ·
  • · Replies 50 ·
  • · Replies 130 ·
19K
  • · Replies 78 ·
