| Thread Closed |
Current in a branch |
Share Thread | Thread Tools |
| Jul14-06, 05:56 PM | #1 |
Current in a branch
I was wondering,when we have a voltage source connected to a node in series with a resistance connected to the ground like this: ,when determining the current on the branches through node method is the current on that branch 5/1k or v1+5/1k?
http://i75.photobucket.com/albums/i2...nchcurrent.jpg and a resistance co |
| Jul14-06, 06:22 PM | #2 |
The current accross the resistor is:
[tex] \frac{V_1-V_g}{1k} | V_g = 0 [/tex] Ground is a node voltage also, you just define it as [itex] 0V[/itex] On a side note, if someone reads this thread...how do I make the "|" larger in LaTeX? |
| Jul14-06, 06:27 PM | #3 |
[tex] \left| \frac{V_1-V_g}{1k} \, \right| \, V_g = 0 [/tex] hmm...was trying the \left and \right command which works for brackets \left( content \right). I only got it to work with a leading \left| command to go with the \right|. Test2: [tex] \frac{V_1-V_g}{1k} \, \Bigg| \, V_g = 0 [/tex] Test3, finally got it ![]() [tex]| \big| \Big| \bigg| \Bigg|[/tex] |
| Jul14-06, 06:37 PM | #4 |
Mentor
Current in a branch
| Jul14-06, 06:50 PM | #5 |
So,the current that passes through the branch where is the voltage source in series with a resistance is (5v-0v)/1k?
| Jul14-06, 06:58 PM | #6 |
Mentor
| Jul14-06, 07:09 PM | #7 |
thanks man! Yeah I was trying the \left and \right commands, but wasn't getting it either. Well cool. I didn't know about the big commands. Thanks again :) |
| Jul14-06, 07:13 PM | #8 |
[tex] f(x,y,z,t) \, \Bigg| \, \begin{array}{c} x=y=z=1 & t =4 \end{array} \,\,\, = 2(1+1+1) [/tex] I believe it means evaluated at, or where... |
| Jul14-06, 07:16 PM | #9 |
And to clarify this above, it would be: [tex] I_{R1} = \frac{V_1-V_g}{1k}=\frac{V_1 -(0)}{1k} = \frac{5}{1k} [/tex] |
| Jul14-06, 07:21 PM | #10 |
But the equation for the node on the left(since the other node is ground) is:
1 + (v1-0)/1k + 5/1k=0 Or is: 1 + (v1-0)/1k + (v1-5)/1k=0 Edit:Thanks for the reply! |
| Jul14-06, 07:24 PM | #11 |
Mentor
I feel much better now. Have a good weekend, all. |
| Jul14-06, 07:27 PM | #12 |
Yeah. I don't know how to do that in LaTeX though |
| Jul14-06, 07:39 PM | #13 |
[tex] f(x,y,z,t) \, \Big|_{\substack {x=y=z=1 \\ t =4}} \, = 2(1+1+1) [/tex] _{\substack{content}} does the trick. Not sure if it could be placed further down, so that the equals sign is placed more to the left. |
| Jul14-06, 07:42 PM | #14 |
For sake of clarity. Lets just assume that your circuit is a single loop. Thus those little branches at the bottom are not connected to anything, so they therefore have no current running through them. so your circuit looks something like this: Code:
____/\/\/______ | | | | ( + ) | ( - ) |--||| | | |____/\/\/_____| The super node expression is: [tex] \frac{V_0-V_g}{R_2}+\frac{V_1-V_g}{R_1}=0[/tex] You write the expression for the voltage: [tex] V_1-V_0 = 5 [/tex] And also note that Vg is defined as 0V so: [tex] V_g = 0 [/tex] THUS, [tex] \frac{V_0}{R_2}+\frac{V_1}{R_1}=0[/tex] [tex] V_1-V_0 = 5 [/tex] Does that make sense? |
| Jul14-06, 07:44 PM | #15 |
To be really picky do you know how to left-justify the expression at the evaluated-at symbol?
| Jul14-06, 07:54 PM | #16 |
http://physicsforums.com/showthread.php?t=8997 [tex] f(x,y,z,t) \, \Big|_{\begin{subarray}{l} x=y=z=1 \\ t =4 \end{subarray}} \, = 2(1+1+1) [/tex] |
| Jul14-06, 08:15 PM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Current in a branch
| branch cuts | Calculus & Beyond Homework | 0 | ||
| Branch cut integration | Calculus | 2 | ||
| why did the current go follow this branch instead the path of least resistance? | Introductory Physics Homework | 8 | ||
| Branch Points and Independent Current | General Physics | 1 | ||
| Branch function | Calculus | 3 | ||
