Thread Closed
parameterization
Share Thread Thread Tools
Jul15-06, 05:50 AM   #1
parameterization
a wheel or radius r rolls along a horizontal straight line.Find parametric equations for path traced by point P on the circumference of the wheel
somebody pls help.
thanx
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jul15-06, 01:26 PM   #2
The curve you are talking about is known as the cycloid. To parametrize this curve, consider the curve at the instant 0 and after t radian. I would start the cycloid at the point (0,0) and then see how the point moved after the circle described a rotation of t radians.
(i.e. investigate how the coordinate's position varies when t does )
One of the things to notice is that, after t radians of rotation, the center of your circle will have moved rt units. This is also the mesure of the arc of circle between your point (x,y) and the point of the circle that touches the horizontal straight line. All of this is due to the fact that the circle rolls without "sliding" on the line.
The fun part is eliminating the parameter....
Edit : I considered the angle t as being the angle between the point (x,y), the center of the circle and the point that touches the straight line. You can also consider a different angle t and the result will also be the same. This choice avoids tricky sign "problems".
Thread Closed
Thread Tools
Similar Threads for: parameterization
Thread Forum Replies
Parameterization of x^(2/3)+y^(2/3)=a^(2/3) Calculus & Beyond Homework 7
Parameterization Calculus & Beyond Homework 3
parameterization Calculus & Beyond Homework 2
Parameterization of Arc Length Function Introductory Physics Homework 8
Line Integral and parameterization General Math 3
