Solving Elasticity Problem: Weight & Columns
  • Thread starter Thread starter mikejones2000
    Elasticity
The discussion focuses on calculating the total weight of ground material that square steel columns must support for a tunnel construction project. The tunnel dimensions are L = 154 m, H = 7.4 m, and width = 6.1 m, with columns having a cross-sectional area of 960 cm². The density of the ground material is established as 2.8 g/cm³, which converts to 2800 kg/m³. The participant initially calculated the weight as approximately 157 tonnes but struggled with unit conversions and density calculations.
  • Understanding of basic physics principles, specifically weight and density calculations.
  • Familiarity with unit conversions between metric units (e.g., grams to kilograms, centimeters to meters).
  • Knowledge of compressive stress and material strength concepts.
  • Basic structural engineering principles related to column load-bearing capacity.
  • Review the principles of calculating weight using volume, density, and gravity.
  • Study unit conversion techniques, particularly for mass and area in structural contexts.
  • Learn about compressive stress and how it relates to material strength in engineering applications.
  • Explore structural design considerations for tunnels, including load distribution and support systems.
Civil engineers, structural engineers, and students in engineering disciplines who are involved in tunnel design and construction projects.
mikejones2000
A tunnel of length L = 154 m, height H = 7.4 m high, and width 6.1 m (with a flat roof) is to be constructed at distance d = 60 m beneath the ground. (See Figure 12-50.) The tunnel roof is to be supported entirely by square steel columns, each with a cross-sectional area of 960 cm2. The mass of 1.0 cm3 of the ground material is 2.8 g.
(a) What is the total weight of the ground material the columns must support?
N
(b) How many columns are needed to keep the compressive stress on each column at one-half its ultimate strength?
columns
I know that for the first question the total weight must be equal to the volume x density x gravity but for some reason I keep screwing up finding the density and the number is much too low. Am I approaching this question badly?
I got something near 157 Tonne of rock.
But my maths is weak.
Make sure your using the right units, wright the units out for each step and ensure that your density is correct ( g per square meter or centimeter ).
[tex] 1m^{2} = 1m\times1m = 10cm\times10cm = 100cm^{2}[/tex]
therefor the density is:
[tex] 2.8g cm^{-2} = 2.8(100)g m^{-2}[/tex]
