Mass of a Singularity: Hawking's Explanation
  • Context: Graduate
  • Thread starter Thread starter Born2Perform
    Mass Singularity
The discussion revolves around the mass of singularities in black holes, particularly in the context of Stephen Hawking's explanations. Participants explore the implications of infinite density, the relationship between mass, volume, and density, and the potential need for a theory of quantum gravity to address these concepts.
  • One participant notes that Hawking states black holes have mass based on the original star's mass plus absorbed matter minus Hawking radiation, questioning why mass would vary if singularities are defined by infinite density.
  • Another participant argues that density is calculated as mass divided by volume, suggesting that mass should not be calculated as density times volume in the case of singularities.
  • A further contribution emphasizes that while density can be infinite, mass remains finite, and the concept of infinite density leads to undefined mathematical scenarios, particularly when considering division by zero.
  • Some participants discuss the implications of quantum gravity potentially altering the understanding of singularities by replacing zero volume with finite volume, though they acknowledge the lack of a current theory.
  • One participant attempts to draw an analogy between the mass-density-volume relationship and a scenario involving distance, speed, and time, questioning the necessity of quantum gravity to understand the mass of black holes.
  • Another participant challenges the logic of using specific examples to prove mathematical concepts, highlighting the ambiguity of dividing by zero and the implications for defining infinity.
Participants express differing views on the implications of infinite density and the relationship between mass, volume, and density. There is no consensus on the necessity of quantum gravity or the validity of the mathematical arguments presented.
Participants acknowledge limitations in their discussions, particularly regarding the undefined nature of certain mathematical operations and the assumptions underlying the definitions of mass and density in the context of singularities.
Born2Perform
In "Universe in a Nutshell" Stephen Hawking says that black holes have mass, and it is the mass of the original star + matter absorbed - hawking radiation in time, or something like it.
Right, but: if a singularity has for definition an infinite density, this mean that it is the maximum density one can think, so why should mass change from black hole to black hole, if the density in a non-dimensional space is alredy the maximum?
Because you calculate the density as mass/volume; you do not calculate (in the case of a singularity) mass as density x volume.
Garth
Garth
D= m/v; D=Infinite
It means that: Infinite*v=m; -----> Infinite=m
What is the problem with this?
mass = finite
volume = zero
density = mass/volume = infinite (a mathemetician might say undefined, because you are dividing by zero)
mass = density * volume = infinity * zero (undefined!)
The moral of the story is that division by zero is bad, and should be avoided.
However, the mass of a BH is not undefined. To see this, go back to the original definitions.
We can measure the mass of a black hole from outside the black hole, (by looking at its orbits a long way away and applying Keppler's law, for instance) - technically this requires that the mass of the black hole not be changing.
So the problem isn't with defining the mass of the black hole, the problem is the idea of having a finite mass in zero volume. I.e. the problem is the infinite density.
Quantum gravity will "probably" replace the zero volume of the singularity with some finite volume, but we don't have a theory of quantum gravity yet.
Just a thing:
s = v*t ; (v=0 ; t=infinite)
s = 0*infinite = 0
why you say it is undefined? in an infinite time a corp that moves at 0 speed makes 0 space.
Isn't the analog case with m = density*volume = infinity*0 = 0?
I just tried to say that in order that black holes mass changes, the density and the voulume cannot be infinite.
I don't see why would be necessary to have a QG to understand what we have alredy...
Born2Perform said:
Just a thing:
s = 0*infinite = 0
there are some serious flaws in your logic... like the use of one sample to decide on a mathematical proof.
For example, 3/0=infinity. So 0*infinity=3.
But 4/0=infinity. So 0*infinity=4
Here's a better question. If you divide 3 by 0, do you get positive or negative infinity?
How can something be defined if you don't know whether it's the left most or rightmost extreme on the numberline? You can't get more divergent than that
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 27 ·
