Young's Modulus and the strain on a sphere due to a uniform pressure
The discussion revolves around calculating the change in radius and resistance of a thin spherical shell, like a beach ball, due to internal pressure. The original poster, Alex, attempts to derive the strain on the sphere using a specific formula and relates it to Young's modulus, but expresses difficulty in applying these concepts correctly to find the change in radius or surface area.
  • Alex presents an initial strain equation and seeks verification, while expressing confusion about applying stress-strain relationships over an area. Other participants question the formulation of Hooke's law and the assumptions made regarding the relationship between radial and surface area expansions.
The discussion is active, with participants providing feedback on the correctness of the stress equation and exploring the implications of linear relationships in the context of small expansions. There is an ongoing examination of the mathematical relationships involved, but no consensus has been reached regarding the final calculations.
Participants are navigating the complexities of applying stress and strain concepts to a spherical geometry, with specific attention to the assumptions about linearity and the relationships between different types of strains. There may be constraints related to the homework guidelines that influence the approach taken.
alex62089
If I have thin shell like a beach ball inflated with air how would I calculate the change in radius and resistance there of due to the pressure inside the sphere? I have calculated the strain on the sphere to be Pr/2h where P=pressure r=radius h= thickness by cutting the sphere in half and assuming that the pressure over the area pi r^2 = the tension in the shell on this plane (2pir(sigma)) so sigma=Pr/2h. I have tried to use this and various stress strain equations, including the young's modulus equation to calculate the change in radius or surfacearea but so far have failed to do so correctly. My biggest problem is in turing this otherwise linear set of equations into ones that work over an area. Could you please verify my strain equation and help me finish my calculations.
Thank you in advance,
-Alex
Your stress equation, [itex]\sigma_{\theta} = \sigma _{\phi} = pr/2h[/itex] is correct.
Next, how did you write out the Hooke's law relation?
And how do you know your answer is wrong?
Stress(sigma)=Young's Modulus(E) * Strain(epsilon or change in length/initial length)
That's what I used and I think that It's wrong because it seems to imply a linear relationship between radial expansion and surface area expansion but intuitively this doesn't seem to be the case. I have tried using dA as the square of dl and differentiating the formula for the surface area of a sphere but don't know if either is mathematically correct.
The length you should be using is the circumference.
For small expansions, you will have a nearly linear relationship between linear, suraface and volumetric strains. Recall, [itex]3\alpha = 2\beta = \gamma[/itex]
  • · Replies 29 ·
  • · Replies 61 ·
14K
