Thiemann's New Theory: Solving Problem of Time in GR & Cosmology
  • Context: Graduate
  • Thread starter Thread starter selfAdjoint
    Theory
The discussion revolves around Thomas Thiemann's new paper proposing a solution to the problem of time in General Relativity (GR) and cosmology through the introduction of a negative energy scalar field termed "phantom." Participants explore the implications of this theory on classical cosmology, the interpretation of the Friedmann equations, and the roles of dark energy and dark matter.
  • Marcus highlights Thiemann's assertion that traditional interpretations of the Friedmann equations as physical evolution equations are incorrect, suggesting they are gauge transformation equations instead.
  • Some participants express uncertainty about the nature of the time parameter in the Friedmann model, questioning its physical measurability and suggesting it may only serve as a convenient tracking tool.
  • Thiemann's model implies that the universe should recollapse at late times, but some participants challenge this claim, noting that the paper acknowledges alternative scenarios like the big-rip solution, which Thiemann dismisses as undesirable.
  • There is discussion on the phantom's behavior at different scales, with some participants noting that it behaves like dust at small scales and as a negative cosmological constant at larger scales, raising questions about the necessity of additional positive energy components.
  • Concerns are raised regarding the introduction of the phantom field, suggesting it does not resolve the dark matter and dark energy issues but rather complicates them by necessitating additional components.
  • Some participants speculate that the phantom scalar field could address the fine-tuning problem by allowing for a positive energy density larger than the observed net energy density of the cosmological constant.
  • The complexity of the paper is noted, with requests for clarification on specific claims, particularly regarding the interpretation of gauge transformations and their implications for physical observables.
Participants express a mix of agreement and disagreement regarding Thiemann's claims. While some find merit in the proposed model, others challenge its implications and the validity of its conclusions, indicating that the discussion remains unresolved.
Participants note the difficulty of the paper and the need for further clarification on several points, including the implications of gauge transformations and the nature of the proposed phantom field. There is also acknowledgment of the unresolved status of dark matter and dark energy within the context of Thiemann's theory.
selfAdjoint
Staff Emeritus
Dearly Missed
Marcus points us to this new paper:
http://arxiv.org/abs/astro-ph/0607380
Solving the Problem of Time in General Relativity and Cosmology with Phantoms and k -- Essence
Thomas Thiemann
He introduces a negative energy scalar field, which he calls phantom because it is unobservable, in order to solve the problem of time in GR. He issues this challenge to common wisdom:
All textbooks on classical GR incorrectly describe the Friedmann equations as physical evolution equations rather than what they really are, namely gauge transformation equations. The true evolution equations acquire possibly observable modifications to the gauge transformation equations whose magnitude depends on the physical clock that one uses to deparametrise the gauge transformation equations.
Any comments?
Space news on Phys.org
selfAdjoint said:
Any comments?
I printed it out and am having a look. In the "links thread" I didn't give the abstract summary of the paper, but if we are going to discuss it , I may as well copy that in
"We show that if the Lagrangean for a scalar field coupled to General Relativity only contains derivatives, then it is possible to completely deparametrise the theory. This means that
1.Physical observables, i.e. functions which Poisson commute with the spatial diffeomorphism and Hamiltonian constraints of General Relativity, can be easily constructed.
2. The physical time evolution of those observables is generated by a natural physical Hamiltonian which is (constrained to be) positive.
The mechanism by which this works is due to Brown and Kuchar. In order that the physical Hamiltonian is close to the Hamiltonian of the standard model and the one used in cosmology, the required Lagrangean must be that of a Dirac -- Born -- Infeld type. Such matter has been independently introduced previously by cosmologists in the context of k -- essence due to Armendariz-Picon, Mukhanov and Steinhardt in order to solve the cosmological coincidence (dark energy) problem. We arrive at it by totally unrelated physical considerations originating from quantum gravity. Our manifestly gauge invariant approach leads to important modifications of the interpretation and the the analytical appearance of the standard FRW equations of classical cosmology in the late universe. In particular, our concrete model implies that the universe should recollapse at late times on purely classical grounds."
the first thing I hope someone will correct or confirm for me is this: it looks to me as if in the context of purely classical cosmology where for generations people have been using the FRW model (the Friedmann equation)
there is a little problem in this classical context simply because the TIME PARAMETER t that one finds in the solution to the Friedmann model is only formally a time parameter. It is not something that could be measured by a clock.
To me it has always looked like a very good time parameter and it is what cosmologists conventionally use to clock the evolution and age of the universe.
but when one scrutinizes it, the classical time parameter in the Friedmann model has only a kind of "honorary" or fiducial existence---it is more adopted for the sake of convenience-----as a parameter to keep track of developments----than as something forced on us by nature.
acknowledging this, if in fact it is true, goes against habit and is damnably awkward. perhaps someone will explain that it is not true, which would be a relief.
in any case this appears to be an awkwardness in the classical picture that carries over into Quantum Gravity. Or perhaps is only really problematical in canonical QG. there is a hamiltonian constraint, with which kosher observables commute, and no time observable commutes and can therefore be kosher.
Thiemann grapples with this by actually concocting an ERSATZ CLOCK in the form of a peculiar scalar field----quite an elusive one, I gather.
Particularly interesting to me are his comments about dark energy and dark matter (since this has immediate practical consequence in cosmology):
Thiemann said:
Notice by the equation of state the phantom behaves
like dust at small scales ρphantom → −E/O3 a and as a negative cosmological constant ρphantom → −α at large scales. This can be easily compensated by additional positive energy k – essence matter or simply by ordinary (dark?) matter plus an additional cosmological constant term  − α > 0. In a sense, if we want to explain the observational fact that the FRW equations describe the universe while their mathematical derivation violates the principles of gauge theory, then something like a phantom is needed for deparametrisation and in turn it requires something like k – essence for reasons of total positive matter energy budget. From this point of view, both a phantom and k – essence are a prediction of the mathematical formalism (gauge theory) together with observation
(FRW cosmology).
It sounds to me like he's saying that he has not solved the dark matter or dark energy problems, but rather given us another potential reason to need to solve them. He has introduced another dark component (the phantom) and said that, in order for this "phantom" to exist and for GR to work, we must have two other "dark" things (dark matter and dark energy). Interestingly, he makes this sound like a strength of the theory. I suppose it is better than adding a phantom that doesn't require dark matter and dark energy.
Also, it's not clear to me that he has given a need for dark matter, just a need for enough matter to balance the early-time contribution of the phantom. That the matter is dark would seem to remain a mystery in this theory.
There might be one positive thing, however. I didn't read the paper in a lot of detail, so perhaps it was discussed, but it seems like this could solve the fine-tuning problem. If the phantom scalar field had negative energy density, then the vacuum could have a positive energy density larger than the observed net energy density of the cosmological constant. In other words, a Planck scale cutoff for QFTs would then be possible.
IMHO this claim is unsupported. In the paper he concedes that the big-rip solution is a possible one and he discards it because it is "clearly undesirable" due to the infinite scale factor. I cannot follow this.
By the way, the paper is very difficult. It would be great if someone could explain the meaning of this fourth "main message":
the usual interpretation of the cosmological framework, although fundamentally wrong because gauge transformations of gauge dependent objects are interpreted as actual physical evolution equations of observables, remains valid when analysed in the correct way, that is, by computing the physical evolution of gauge invariant observables
  • · Replies 19 ·
  • · Replies 153 ·
14K
  • · Replies 60 ·
