Electron Redistribution and Self-Repulsion in Antennas
  • Context: Graduate
  • Thread starter Thread starter Firefox123
    Antenna
The discussion revolves around the behavior of electrons in an antenna when subjected to varying voltage conditions, specifically focusing on the effects of a square wave voltage signal. Participants explore the implications of applying a 10 volt peak-to-peak square wave and the resulting electron flow during different voltage states, including the transition to zero volts.
  • One participant describes how electrons flow in one direction when a positive voltage is applied and in the opposite direction when a negative voltage is applied, questioning the behavior when transitioning to zero volts.
  • Another participant introduces the concept of phase difference in circuits with impedance, suggesting that the slope of voltage change is critical for electron flow, rather than the sign of the voltage itself.
  • There is a discussion about the differences between antennas and capacitors, with one participant asserting that while capacitors have predictable behavior, antennas introduce complexity.
  • One participant proposes that the reversal of electron flow during the zero voltage period could be due to the electrons returning to their original state, influenced by electromagnetic repulsion.
  • A later reply supports the idea of self-repulsion as a mechanism for charge redistribution when no external field is present.
Participants express differing views on the behavior of electrons in antennas versus capacitors, and while there is some agreement on the role of self-repulsion in charge redistribution, the overall discussion remains unresolved regarding the specific mechanisms at play in the context of antennas.
The discussion highlights the complexity of electron behavior in antennas, particularly in relation to impedance and voltage transitions, without reaching a consensus on the underlying physics.
Firefox123
Let me rephrase my question here, since some of the responses in the orignal thread arent really what I am after, maybe this is more of a physics question than an electrical engineering one...
If we apply a 10 volt peak to peak square wave to an antenna (assume the signal goes from +5 volts to -5 volts) we have the following situation...
During the time we apply the +5 volts the electrons in the antenna "flow" in one direction and during the time we apply the -5 volts the electrons in the antenna "flow" in the opposite direction.
Now we apply a 10 volt peak to peak square wave that will range from 0 volts to + 10 volts. What happens to the electrons in the antenna in this case?
During the time we apply the +10 volts I can see the electrons "flowing" in the same direction as they did when we applied +5 volts. But when we change the applied voltage from +10 volts to 0 volts I am not sure why they would flow in the opposite direction since we arent really applying a negative voltage, we are applying no voltage at all.
Does this occur because during the time we apply +10 volts the electrons become "displaced" in one direction and then when we drop the voltage dwon to zero the electrons return to the original state due to the electromagnetic repulsion between electrons (before we applied any voltage)?
Is this a good explanation of why the electrons would move in the opposite direction during the period of no applied voltage?
Russ
taking an antenna makes things more difficult, is this necessary ?
Moreover, on any impedance different from a purely resistive one, you have a phase difference between the voltage and the current. The voltage might be positive, and nevertheless, the current might flow out of the load and into your generator.
The impedance of an antenna depends on the frequency used, its structure...
So let us rather take a capacitor. You're already in for a surprise btw.
When the voltage rises, electrons will flow out of the capacitor into your generator. When the voltage is constant, nothing will move. When the voltage will lower, electrons will flow from the generator into the capacitor. It doesn't matter what sign the voltage has, it is the slope that counts. That's why the equation for a capacitor is:
i = C dv/dt.
Yes it is necessary because I am looking at what happens in the two cases I describe above.
Im looking for the cause of the electrons reversing direction when we apply zero volts.
Yes, I know.
Actually nothing you wrote surprises me. I already knew about electron flow in a capacitive circuit.
i = C dv/dt.
Yes I know this. If you charge up a capacitor to a certian source voltage in a circuit and then reduce the source voltage the stored charge in the capacitor will cause charge to flow in the opposite direction (opposite to the direction that it was flowing during the charging cycle).
But a capacitor is not the same thing as an antenna (although there are similarities I will admit).
As for my antenna example given in the first post...
Can we say that the reason the electrons will move in the opposite direction during the 0 volt time period is because they are returning to the original state in the wire before we applied the 10 volts?
Can we also say that, since 0 volts implies no voltage, that this reversal of direction is caused by the repulsion of the electrons (which have been slightly displaced to one end of the antenna due to the +10 volts we applied a moment ago) with one another?
This sounds like a reasonable physical explanation to me. Thoughts?
Russ
Self-repulsion. It's what causes charges on a surface to redistribute themselves when there are no external field.
Zz.
Zz.
Thank you. I agree that this must be the cause. Its nice to have someone confirm this.
I will accept this explanation as correct until someone can prove it wrong.
Russ
  • · Replies 28 ·
  • · Replies 33 ·
