Independence and conditional probability
The discussion centers on the conditional probabilities involving independent events X and Y, which are not independent of event A. The equality P(X, Y | A) = P(X | A) * P(Y | A) holds true under the assumption that X and Y are independent. The problem presented involves calculating P(A | X, Y) using Bayes' Theorem, given P(A), P(X | A), and P(Y | A). The events X and Y are defined as testing negative and positive in a drug test, respectively, while A represents the event of having a disease.
  • Understanding of conditional probability and independence
  • Familiarity with Bayes' Theorem
  • Knowledge of mutually exclusive events
  • Basic concepts of probability theory
  • Study the application of Bayes' Theorem in real-world scenarios
  • Explore the implications of independent and mutually exclusive events in probability
  • Learn how to calculate joint probabilities for independent events
  • Investigate the use of probability trees for visualizing complex probability problems
Mathematicians, statisticians, data scientists, and anyone involved in probability theory or statistical analysis, particularly in contexts involving conditional probabilities and Bayes' Theorem.
island-boy
if X and Y are events which are independent of each other, but neither are independent with A,
is this equality true for conditional probabilities:
P( X, Y | A) = P(X|A) * P(Y|A)
if not,
how do you solve for P(A | X,Y)
given that you only know P (A) and P(X|A) and P(Y|A)?
The reason I came up with the above probability where I have:
[tex]P(A| X, Y) = \frac {P(X, Y | A) P(A)}{P(X, Y |A) P(A) + P(X, Y | A^c) P (A^c)}[/tex]
is that I used Baye's Thm.
Note: P(X, Y |A) is not given.
First, by P(X,Y) do you mean P(X and Y) or do you mean P(X or Y)?
Assuming that you mean P(X and Y) then, yes, since X and Y are independent, P(X)= P(Y) so P(X and Y| A)= P(X|A)P(Y|A).
Cheers for the help, HallsofIvy.
well, this is how it is stated in the problem:
X is the event of testing negative in a drug test
Y is the event of testing positive in the drug test
A is the event of having a disease.
Given that a person went to have a drug test three times, testing positive once and negative twice. What is the probability he has a disease?
here, X and Y are mutually exclusive events. However, are [tex]X_1[/tex] and [tex]X_2[/tex] mutually exclusive? It would seem that testing thrice would mean the question is asking for the union of the 3 events. Is this correct?
so would the solution be
[tex]P(A| X, X, Y) = \frac {P(X|A)P(X|A)P(Y|A)P(A)}{P(X|A^c)P(X|A^c)P(Y|A^c)P(A^c)}[/tex] ?
  • · Replies 18 ·
