Area of a surface of revolution
The discussion revolves around finding the area of a surface of revolution defined by the equation 9x = y^2 + 18, specifically between the x-values of 2 and 6. Participants are exploring the integration process involved in calculating this area.
  • Participants discuss the setup of the integral for the surface area, questioning the correctness of terms and signs in the integrand. There are attempts to simplify the integral through algebraic manipulation and substitutions.
Multiple interpretations of the integral are being explored, with some participants suggesting corrections to earlier expressions. Guidance is offered regarding algebraic manipulation and substitution methods, but no consensus on a final approach has been reached.
There are indications of potential sign errors in the expressions being discussed, and participants are working within the constraints of the problem as posed, without additional context or information.
suspenc3
9x=y^2+18 between 2&6..so y=(9x-18)^1/2
and dy/dx= [tex]\frac{9}{2 \sqrt{9x-18}}[/tex]
so [tex]S = 2 \pi \int_2^6 \sqrt{9x-18} \sqrt{1+ \frac{81}{36x+72}}dx[/tex]
If this is all right..then I am stuck
Any help?
Well first, you have a sign error in the denominator of the second term. Should be -72.
To integrate, you could mulitply the terms in the square roots and manipulate them algebraically to get something simpler.
[tex]S = 2 \pi \int_2^6 \sqrt{9x-18} \sqrt{1+ \frac{81}{36x-72}}dx[/tex]
[tex]S = 6 \pi \int_2^6 \sqrt{x-1/4} }dx[/tex]
Using the substitution u = x+1/4 you will get your answer
Hope it helps.
I think you should get [tex]S=6\pi\int_2^6\sqrt{x+\frac{1}{4}}dx[/tex]
Also, since [tex]x+\frac{1}{4}[/tex] is linear, you can use the standard formula:-
[tex]\int(ax+b)^ndx=\frac{(ax+b)^{n+1}}{a(n+1)}+c[/tex], where n is unequal to -1.
How did you get this?
Consider, [tex]\sqrt{9x-18} \sqrt{1+\frac{81}{36x-72}}=[(9x-18)(1+\frac{81}{36x-72})]^\frac{1}{2}[/tex]
Carry out some factorization and re-expression and you should get what I got!
  • · Replies 105 ·
13K
