Do massless particles always have momentum in the direction of travel?
The discussion revolves around whether massless particles, such as photons, always have momentum in the direction of their travel. Participants explore the implications of momentum in the context of special relativity and electromagnetic fields, raising questions about the nature of momentum and its relationship to directionality.
  • Some participants assert that momentum for zero rest mass particles is indeed in the direction of motion, referencing the relationship p=hbar * omega / c.
  • Others question whether momentum can be considered a scalar quantity, suggesting that its derivation from energy implies it may not always align with direction.
  • One participant proposes a hypothetical scenario where gravity could be modeled by virtual particles with momentum opposing their direction of travel, raising concerns about energy conservation in static situations.
  • Another participant argues that in static gravitational fields, virtual particles cannot carry momentum away from a static body, while in dynamic situations, momentum must align with the direction of motion.
  • Some participants discuss the concept of canonical momentum in electromagnetic fields, noting that it can differ from linear mechanical momentum and may not always align with velocity.
  • A participant highlights that the original poster may be considering linear mechanical momentum, which is typically associated with mass, and questions the validity of applying canonical momentum to massless particles.
Participants express differing views on the directionality of momentum for massless particles, with no consensus reached. Some maintain that momentum is always in the direction of travel, while others explore scenarios where this may not hold true.
Participants reference various frameworks, including special relativity and electromagnetic theory, which may influence their interpretations of momentum. The discussion includes assumptions about definitions of momentum and the conditions under which different types of momentum apply.
NateTG
I'm not sure this is the right forum, but I wanted to ask the following (possibly bizarre) question:
Is it implicitly assumed that zero rest mass particles have momentum in the same direction as they travel?
Yes, but this is not an assumption. Momentum for zero rest mass particles is given by:
p=hbar * omega / c
where hbar is Planck's constant divided by 2*Pi and omega is the angular frequency.
But isn't that a scalar quantity:
[tex]\left|\vec{p}\right|=\hbar \omega c[/tex]
The derivation I've seen is from special relativity and starts with energy (also scalar).
Yes, that's true. Also true is that momentum is always in the direction of motion. The quantum hypothesis is that [itex]\vec{p} = \hbar \vec{k}[/itex]. The k vector is in the direction of motion, always, for any particle.
how can momentum NOT be in the direction of motion?
I don't see what the problem is. For example, it seems like it should be possible to model gravity as being propogated by virtual particles that have linear momentum opposing the direction of travel.
It's not possible. If you're talking about the static GMm/r^2 force, one can't view that force as being carried by virtual particles at all. Any virtual particles carrying momentum (hence energy) must take it away from the static body, draining energy away somehow. That doesn't happen. This is true in GR as well, so long as the situation is static.
If the situation is not static, ie gravity waves, momentum (hence energy) is carried away from the body. Particles radiated from the body must hence carry momentum in the direction of motion. The only way to get around this would be to have particles come in from infinity carrying momentum in the opposite direction of their motion, which would be the ultimate example of non-locality.
you should read more about force carying particles... static EM fields do have virtual photons just like gravitation might have virtual gravitons... though i don't understand how can momentum in a different direction might exist
Mostly this was supposed to be a, 'has anyone tried this' sort of post more than anything else.
Not that I'm claiming that momentum-velocity separation is necessarily a good idea, but stranger things have been successful in physics.
It depends on what is meant by "momentum". In an EM field, the "canonical momentum" of a charged particle is given by
p=mv\gamma+qA/c. In that case, p and v need not be in the same direction.
Its quite possiible within the domain of special relativity. If the body whose momentum you seek is under stress then the momentum of the body need not be in the direction of motion. However the total momentum of a closed system is always in the direction of its velocity.
Pete
Well, it's a tricky question.. Usually, momentum WILL be in the direction of motion unless its an alternative force that is creating the motion while pushing it away aswell... ---> O< Have you tried taking a look at EMF papers?
It seems clear that the OP is thinking about linear mechanical momentum mv since this is the quantity which says that a photon has a proper mass E^2 - (pc)^2 = 0. The p in that exxpression is linear mechanical momentum. If you put in the canonical momentum then the expression looses its meaning.
Even if the OP was referring to canonical linear momentum then the momentum is still in the direction of the velocity. Notice that the photon has zero proper mass and zero charge so that
p=mv\gamma+qA/c.
is invalid. Notice also that a photon has no charge so that A will be zero.
Pete
  • · Replies 36 ·
10K
