String number density - does it make sense?
  • Context: Graduate
  • Thread starter Thread starter frank_k_sheldon@yahoo.co.uk
    Density String
The discussion centers on the concept of string number density within the framework of string theory. A moderator explains that while one can define a "number of strings" operator in a perturbative treatment, this quantum number is not conserved and varies with energy scales. Specifically, at high energy levels, such as 1019 GeV (Planck energy), the density may approximate one string per mm3, while at lower energies like 1 eV, the density is significantly higher. The conversation highlights the complexity of quantifying string density in both empty space and under varying energy conditions.
  • Understanding of string theory fundamentals
  • Familiarity with quantum field theory (QFT)
  • Knowledge of energy scales in particle physics
  • Concept of perturbative treatments in theoretical physics
  • Research the implications of energy scale on particle density in quantum field theory
  • Explore the concept of string coupling and its effects on string density
  • Investigate the relationship between string theory and quantum chromodynamics (QCD)
  • Examine methods for estimating particle densities at various energy levels
The discussion is beneficial for theoretical physicists, researchers in string theory, and students studying quantum field theory, particularly those interested in the implications of energy scales on string density.
On a blog I came across a strange question:
"Does it make sense to speak about the number of
strings found in a volume of space?"
Could anybody comment on this? I would be
interested if one has to imagine string theory
as filling all of space with strings Or branes),
or whether this is the wrong visualization.
Frank
[Moderator's note: one can construct the "number of strings" operator in a
perturbative treatment of string theory - much like you can talk about
the number of particles and/or the level of the harmonic oscillator.
However, both in quantum field theory and string theory, this quantum
number is a bit problematic. It is certainly not conserved. In QFT, it
depends on the energy scale at which you understand the system - because
with a high enough scale, you find very many gluons inside the proton,
to say an example. The "number of particles" behaves strangely when
you include interactions. The latter statement is also true in string
theory. The real physical objects at nonzero coupling are not just the
"bare 1 string" that you know from g=0. LM]
> strings found in a volume of space?"[/color]
> "bare 1 string" that you know from g=0. LM][/color]
I was always looking for answers to the comment, but saw the
moderator's note only today.
To continue on the QCD analogy, the number of strings would
thus depend on the energy. I suppose this also correct for empty space.
Thus the number of strings in empty
space will depend on the energy. (Correct?)
If this is so, can we give numbers?
I suppose that at 10^19 GeV (Planck energy), the number is maybe one
string per mm^3 (or probably one string for any volume whatsoever),
whereas at 1 eV it is very high. Is this correct?
And if so, can one give an estimate for the number of strings at 1eV
in flat empty space? (Or does one need to specify some other
condition?)
That is really an interesting issue!
Frank
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 21 ·
