 Quote by pivoxa15
Could someone give a basic and concise explanation for it? Its surprising that textbooks talk about this example as how electricity and magnetism were first considered together but not explain why it was the case.
Does the needle spin indefinitely? Or does it eventually point towards a specific direction?
I'll have a stab at it. A current in a wire sets up a magnetic field around the wire. It is this magnetic field which interferes with the magnetic field set up by the compass thereby disrupting its field causing the compass to spin. This is because the north pole 'want' field lines to be coming out and the south pole 'wants' field lines inwards. The compass will have to move from its original position in order to achieve this configuration again. But once it has achieved this with the new field (assuming a constant current) the compass should stop moving?
Well, do you understand why the magnetic dipole moment of a ring of current that spins freely on an axis of rotation (could be a ring or a square) aligns itself with a uniformly applied B-field? Do the analysis yourself (analyze the torques that are applied to the ring of current and determine what the equilibrium position of the ring ends up being). Take a square ring of current lying in the x-y plane which has an axis of rotation along the x-axis and then apply a uniform B-field in the y direction. You will find that the magnetic moment of the ring of current will align itself with the externally applied B-field.
Now, realize that a simple bar magnet's (for instance, the arrow of a compass is a bar magnet) magnetic moment is also caused by currents, which is the same way a ring of current's moment is produced. However, the current in a bar magnet is formed by Eddy currents flowing in the magnet. However, much like the moment of the ring of current aligns with the external B-field, the moment in the bar magnet aligns with the B-field set up by the current. This can be clearly understood when you understand how a ring of current aligns with a B-field.
This is probably confusing and I apologize. I just got off work and I'm tired.
