DaveC426913
2025 Award
- 24,551
- 8,869
(This is about SR. Really.)
While learning sailing the other day, I was told I was understeering when tacking. Here's my problem:
1] "Close haul" is a Point-of-Sail less than ~30 degrees (or so) from head-to-wind. (i.e. if the wind is coming an angle less than 30 degrees off the bow, you are on a Close Haul PoS.)
2] "Tacking" is the act of turning the boat through the wind from a Close Haul on one side, to a Close Haul on the other side.
Thus, in performing a successful tack, you will change direction by (30 +30) = no more than 60 degrees, right?
Wrong!
3] A successful tack will have you pass through a full 90 degrees. It will do this without violating rules 1 and 2.
How can this be? When does 30+30=90?
When the axes of wind direction do not stay fixed wrt the boat as it turns.
(Let's take just one half of the tack for simplicity) Even though I rotate the boat from "30 degrees from head-to-wind" to "zero degrees from head-to-wind", the boat must actually rotate a full 45 degrees to do this.
Why? Because (forget the turn for a minute, let's look at a boat going straight) the forward motionof the boat changes the angle of the wind wrt the boat itself, moving the angle from an actual 45 degrees to an apparent 30 degrees. When the wind was coming across the bow at 30 degrees, that was wrt and obnserver in the boat's frame of reference. An observer in the water would calculate an angle of wind wrt boat as 45 degrees.
Thus, on the boat, a 60 degree wind-direction-change requires a 90 degree boat-direction-change.
As my skipper explained it, the wind angles "scissor together". And the faster you are travelling, the more they scissor together.
This was a moment of Zen. This "scissoring axes" is a term I've heard elsewhere, in physics texts, and in threads discussing time dilation, explaining the distortion of spatial and temporal axes at relativistic speeds.
But I can't quite get the thought to gel in my head.
Sometimes my brain can smell a personal higher understanding of the universe - but on the whim of a breeze, it is lost. Damn you middle-aged brain.
Wrong!
