Thought Experiment with Iron wire
The discussion revolves around a thought experiment involving a cylindrical magnet wrapped with iron wire, focusing on the effects of applying a DC current to the wire while it is saturated with the magnet's field. Participants explore the implications of magnetic saturation, the behavior of magnetic flux lines, and the relationship between the magnet's field and the induced field from the current.
  • Jason O proposes a scenario where a cylindrical magnet is wrapped with iron wire, questioning the behavior of magnetic flux lines when the wire is saturated and a DC current is applied.
  • Some participants express confusion about the setup, questioning the practicality of using uninsulated wire and the implications of saturation on magnetic pathways.
  • One participant suggests that saturated iron windings may not provide a magnetic path that allows for further magnetic expression in free space.
  • Another participant discusses the concept of saturation, indicating that it optimizes the magnetic pathway and that external magnetic flux lines will tend to follow this optimized path.
  • There is a debate about whether the relationship between the input current and the magnetic flux released from the permanent magnet is linear or non-linear.
  • Participants discuss the idea of "releasing" magnetic flux and clarify that the focus is on understanding the interactions of magnetic fields in saturated versus unsaturated states.
  • One participant introduces the concept of magnetic monopoles in relation to the discussion, although it remains unclear how they apply to the thought experiment.
  • Another participant suggests considering the analogy of parallel resistors to understand how magnetic fields interact with different materials.
Participants express various viewpoints, and no consensus is reached regarding the behavior of magnetic flux in the proposed scenario. The discussion remains unresolved with multiple competing ideas about the effects of saturation and the relationship between the magnet's field and the induced field.
Participants mention limitations in understanding the relationship between the input current and the magnetic flux, as well as the practical implications of using uninsulated wire. There are also references to saturation curves and the behavior of magnetic fields in different materials, but these concepts are not fully resolved.
Jdo300
Hello All,
Consider the following. Take a cylindrical magnet (say 2” long by 0.5” diameter and wrap it with iron wire in such a fashion that the windings do not touch (assuming it is uninsinuated). Wrap just enough turns of wire so that the magnet’s field is essentially short circuited through the iron, but use only enough iron to absorb the field you need (should be about saturated).
Now, let’s say that this magnet has a field strength of 5 units and the iron wire is completely saturated with the 5 units of flux from the magnet. If I then apply a DC current in this iron coil that causes it to produce a magnetic field with one unit of strength (while the iron wire is saturated with the permanent magnet’s field) what will happen?
1. Will the flux lines from the permanent magnet that were shorted through the iron wire go through the air since the wire would be saturated from the current?
2. If the flux from the permanent magnet comes out of the iron, will the iron wire release 1 unit of the permanent magnet’s field for every unit of magnetic energy the coil produces, or is this relationship likely to be non-linear?
I would appreciate anyone who could shed some light on this.
Thanks,
Jason O
Maybe it's just because of the beer, but that question makes no sense to me. Why, for instance, would you try to wrap uninsulated wire into a solenoid and avoid contact with adjacent coils, when you can just use regular insulated magnet wire? :confused:
edit: Ooops! I just noticed that I had the wrong smilie there. Sorry 'bout that. The grumpy one was a typo.
I think you are asking if the "saturated" iron windings no longer provide a magnetic path which would not entail a further "free-space" magnetic expression.
You would be correct. The saturated condition of the windings would act merely as a functional extension of the magnet.
Hi,
Thank you for your help. So, if I am interpreting what you are saying correctly, once the iron wire is saturated from the input current, the magnetic flux lines of the permanent magnet will no longer go through the iron? What kind of relationship would this be for the iron? I am essentually trying to see if I can completely 'swtch' the flux of the magnet between going through the iron and free air, but I am wondering how much input this requires into the iron to cause this effect. Would I need to put in enough current to create one unit of magnetic flux to release one unit of magnetic flux of the permanent magnet from the iron, or would this relationship likely be non-linear? Is there any way I could calculate this?
Thank you,
Jason O
Jdo300 said:
Hi,
Thank you,
Jason O
Ok. Let's examine this:
"...if I am interpreting what you are saying correctly, once the iron wire is saturated from the input current, the magnetic flux lines of the permanent magnet will no longer go through the iron?"
No. Saturation is only an aspect of complete alignment within the potential magnetic domains of the target material. As such, saturation provides for an optimum magnetic pathway and external magnetic flux lines will tend towards a path of optimization.
"What kind of relationship would this be for the iron?"
The iron acts as an extension of the magnetic expression, even more so under "saturated" conditions.
"I am essentually trying to see if I can completely 'switch' the flux of the magnet between going through the iron and free air..."
Sure, this can be done, but at a cost of energy expenditure.
"Would I need to put in enough current to create one unit of magnetic flux to release one unit of magnetic flux of the permanent magnet from the iron, or would this relationship likely be non-linear?"
Ah, the magic question.
Until magnetic monopoles are verified and somehow deemed to be manipulative, there is no "release"
How would magnetic monopoles be of any use in this case? Also, what do you mean by "release"? I am just interested in understanding the interactions of magnetic field flow through the iron in saturated and unsaturated states. Would you or anyone else here know of any good, relevant resources I can check to understand the physics of this situation?
Thank you,
Jason O
Hi Jason.
I used the word "release" because you used it in the question, so I assumed you were referring somehow to monopoles. Perhaps I was wrong.
Question for you, though: Are you trying to "isolate" a magnetic field from it's source?
Also, when I have more time today, I should be able to locate some good references for you.
pallidin said:
Hi Jason.
Hi Pallidin,
Sorry for the confusion; when I mentioned the word "release" in I should have said "switch", as in causing the field to want to flow through the open air rather than the iron wire.
As for your second question, no, I don't want to isolate the permanent magnet's field from the magnet itself, I simply want to switch/redirect the flux flow of the magnet from going through the iron to going through the air by saturating the iron wire (not sure if this is how it would work though).
Thanks,
Jason O
It might help to think of it this way.
A piece of iron represents a reduced resistance to the magnetic field.
However, the iron only has a limited number of paths that reduce the resistance.
You seem to have this idea ok.
You seem to need to think about parallel resistors though. The air is still there. Some of the field will always go through the air.
When the magnetic paths in the iron are all filled up
the field will still flow though the area occupied by the iron, it just won't have the advantage or the resistance reducing effect.
For example wrap two copper coils together around a bit of iron.
Use meter to measure L of one coil.
Put a DC current through the second coil.
The measured L will get smaller in the first coil as you increase the DC current up to the saturation point and then stay about the same(see saturation curves).
All the field must still travel through the inside of the coil, which just happens to be filled with iron.
  • · Replies 37 ·
