How Do You Calculate the Time Interval Between Bounces of a Ball?
The discussion revolves around calculating the time interval between bounces of a steel ball that bounces elastically on a steel plate, with a maximum height of 20.2 m. Participants are exploring kinematic equations and the relationships between distance, velocity, and acceleration in the context of this bouncing ball problem.
  • Participants are attempting to use kinematic equations to find the time interval between bounces, questioning their calculations and the application of the equations. Some are exploring the relationship between the time taken to reach maximum height and the total time for a bounce cycle.
The discussion is ongoing, with participants sharing different approaches and calculations. Some have provided specific values for time but are questioning their correctness. There is a mix of interpretations regarding the application of kinematic equations, and no consensus has been reached yet.
Participants are working under the constraints of the problem's parameters and the requirement to find the time interval without complete solutions being provided. There is a focus on the assumptions made in the calculations, particularly regarding acceleration due to gravity and the initial velocity of the ball.
taveuni
Hi:
I am working through this problem regarding a bouncing ball. I have gotten most of the way through, but can't figure out the time interval between bounces. Can someone give me some guidance? What am I not seeing?
A 32 g steel ball bounces elastically on a steel plate, always returning to the same maximum height h = 20.2 m.
a) With what speed does the ball leave the plate?
vup = 19.9m/s
b) What is the magnitude of the total change in momentum of the ball with each bounce?
|Dpball| = 1.27
c) What is the magnitude of the total momentum the ball transfers to the plate at each bounce?
|Dpplate| = 1.27
d) What is the time interval between bounces?
Dt = ?
I tried to simply t=d/v=20.2/19.9 and multiplying that by 2-- wrong. I can't think of any other way to solve this. And the next question builds off of it:
e) Averaged over a long time interval, what is the magnitude of the rate at which momentum is transferred to the plate?
|Dp/Dt| =
f) What is the magnitude of the average force exerted by the ball on the plate?
Favg =
Thank you...
Time interval between bounces...
knowing the laws of kinematics, can you calculate how long it takes for an object to move a set distance, given the acceleration?
I know
dx=vo*t+(a*t^2)/2
But that doesn't give me the right answer
I got 0.84s ---
Is there something I am completely missing here?
dx=vo*t+(a*t^2)/2
20.2 = 19.9t + 9.81/2*t^2
solving for t = 0.84 or -4.9
2*t = 1.68s. Wrong.
Please, does anyone have any suggestions?
Thank you so much.
20.2=9.81/2*t^2,=>t=2.03
or 20.2 = 19.90792t - 9.81/2*t^2
[tex]v = v_0 + at[/tex]
[tex]v - v_0 = at[/tex]
[tex]t = \frac{v - v_0}{a}[/tex]
v - velocity of the ball when reaches the maximum height
v0 = vup = 19.9m/s
a = g = - 9.80 m/s2
t - That's the time the ball will take to reach the maximum height.
But the time interval between two bounces let's call tb is equal to 2t.
Then:
[tex]t_b = 2(\frac{v - v_0}{a})[/tex]
  • · Replies 23 ·
