Calculating Spring Constant for Maximum Acceleration of a Car
The discussion revolves around calculating the spring constant, k, for a spring intended to stop a 1200 kg car from a speed of 100 km/h while ensuring the occupants experience a maximum acceleration of 5.0 g. Participants are examining the appropriate equations and methods to derive the spring constant.
  • Mixed
  • Participants are exploring various equations, including kinematic equations and Hooke's Law, to find the spring constant. There are differing values being calculated, with some participants questioning the validity of using certain equations due to the nature of acceleration involved.
There is an ongoing debate regarding the correct approach to the problem, with some participants providing alternative methods and calculations. While some express confidence in their reasoning, others acknowledge potential misunderstandings about the nature of acceleration in the context of the problem.
Participants are discussing the implications of constant versus variable acceleration in relation to the equations being used. There are references to classroom dynamics and disagreements with a teacher regarding the interpretation of the physics involved.
Hollysmoke
Okay, I'm having a debate with my teacher. He's saying I'm wrong but I still think I'm right. The question is:
What should be the spring constant, k, of a spring designed to bring a 1200kg car to rest from a speed of 100km/h so that the occupants undergo a maximum acceleration of 5.0g?
He said to use the equations v2^2 = v1^2 + 2ad and 1/2mv2^2=1/2mv1^2+mad
I said ma=kx, ma/k=x
then 1/2mv^2=1/2k(ma/k)^2, solve for k and I get 3700, whereas he got 14,000. Could someone please help me out with this?
Infact, I get a value of just over 14,000 using your method. Did you convert the speed to m/s? Also use g = 9.8 ms-2.
I used g, yes. and I did convert.
I'm really sorry, I actually get a value of just over 3700.
What formula is that?
I would do it differently. :-p
First, I used this formula do find the displacement of the spring:
[tex]v^2 = {v_0}^2 + 2ax[/tex]
It gives [tex]x = 8.0[/tex] m.
Then, I used Hooke's Law to find the spring constant.
[tex]F = -k.x[/tex]
[tex]m.a = -k.x[/tex]
[tex]k = \frac{-m.a}{x}[/tex]
[tex]k = \frac{-1200 \times -5 \times 9.80}{8}[/tex]
[tex]k = 7350[/tex] N/m
Yes, I did too!
See, my reasoning is, F=ma=kx, but k and m are constant, therefore when a greater force is applied to scretch the spring (or in this case, compress), acceleration changes (as well as x). However, the other two equations involves a uniform acceleration, which you can't have in this case.
But in this case, isn't the car undergoing a constant acceleration of -5g?
You cannot use [itex]1/2mv2^2=1/2mv1^2+mad[/itex] because the acceleration is not constant.
If the maximum acceleration is 5 g = -49 m/sec^2 then kd = 5mg where d is the stopping distance. So k = 5mg/d
The work done in stopping the car is stored in spring: [itex]\frac{1}{2}mv^2 = \frac{1}{2}kd^2[/itex], so:
[tex]kd^2 = 5mgd = mv^2[/tex]
[tex]5gd = v^2[/tex]
[tex]d = v^2/5g = 15.75 m[/tex]
So k = 5mg/d = 5*1200*9.8/15.75 = 3700 N/m to two significant figures.
AM
Ah... of course it is not constant. Sorry, my mistake.
It's a maximum acceleration
Hollysmoke said:
Yes, I did too!
I can't check the numbers right now but your method seems correct. And of course, as you pointed out, the equation he suggested is wrong because the acceleration is not constant. I am sure that when you tell him/her that, he will slap himself and agree with you!
Yes, know I understand. I was naive.
Thank Hollysmoke and Andrew Mason! :approve:
Actually, that's why I'm here. I told him and he brushed me off, saying F=ma=kx <- Acceleration is constant. I actually just stormed out of the class and had a discussion with the VP about it. I just wanted to make sure I wasn't making a total ass of myself though. Thanks for your help :3
Ask him how the force can be constant if x changes. If he says it doesn't change, ask him to explain physically how the spring slows the car down. Perhaps there we have a different understanding of how the spring is configured.
AM
Okay, I'll do that. I'll tell you how it goes tomorrow ^^
I am flabbergasted!
I mean, I can imagine a prof being distracted and for a second using an invalid equation, but to *defend* that the acceleration is constant for mass connected to a spring is amazing. Wow...
Good luck!
