What is Einstein's Box in Physics?
  • Context: Graduate
  • Thread starter Thread starter Arcon
    Box
The discussion revolves around Einstein's Box, a conceptual framework used to explore the implications of relativistic physics, particularly in relation to energy, momentum, and the behavior of photons within a defined system. Participants examine historical derivations, propose hypothetical scenarios, and discuss the implications of relativistic effects on these scenarios.
  • One participant describes Einstein's original derivation of the inertia of energy and the center of mass vector, noting modifications made by others, including their own work.
  • Another participant questions how the introduction of two photons into Einstein's Box would affect the system, particularly under relativistic speeds, raising issues of momentum conservation and simultaneity.
  • A different perspective is offered regarding the interference of two photons with different phases, suggesting that they could potentially cancel each other out under specific conditions.
  • Some participants reference modern interpretations of Einstein's Box, indicating that assumptions about the rigidity of the box may not hold in contemporary discussions.
  • Technical discussions arise concerning the mathematical treatment of forces and the implications of lowering indices in equations related to gravitational force.
Participants express differing views on the implications of introducing photons into Einstein's Box, particularly regarding momentum transfer and the effects of relativistic speeds. There is no consensus on the outcomes of these hypothetical scenarios, and the discussion remains unresolved.
Participants highlight various assumptions, such as the rigidity of the box and the treatment of simultaneity in relativistic contexts, which may affect the interpretations of the scenarios discussed. The mathematical steps involved in the derivations and their implications are also noted as potentially unresolved.
Arcon
In 1906 Einstein utilized the center-of-mass theorem to derive an expression for the inertia of energy and an expression for the center of mass vector. The paper consisted of two parts the first of which was a spring board for the second part. The first part was entitled "A special case" and the second part was entitled the "On the Principle of the Conservation of the Center of the motion of the center of gravity"
I've created a new web page which describes Einstein's derivation. The page also describes one modification given by Antipa in the Am. J. Phys. I've made one slight modification of his argument by using the principle of the conservation of (relativistic) mass.
This derivation is commonly known referred to as "Einstein's Box"
http://www.geocities.com/physics_world/sr/einsteins_box.htm
Caution: Please don't confuse the center of mass "frame of reference" with the center of mass "vector." Einstein's work as well as Antipa's, mine and anyone else who describes this work of Einstein's pertains to the center of mass *vector*
So if you take Einstein's box, and put two photons in it, going from opposite sides, would the result be different? Now boast that frame. Are the two photons still in opposition? What changes as the box goes relativistic speeds to the observer?
Which result are you referring to? Einstein assumed that the box was a rigid body and the photon gave a kick to the box. The box had to move otherwise momentum would not be conserved. The mass of the box moving was then used with conservation of the center of mass and the result of the calculation was m = E/c^2/. If you have two photons kicking then not momentum is transferred to the box. However more modern versions of this experiment don't assume the box is rigind - e.g. French's example of Unhinging Einstein's Box etc.
In your example you're using a situation which is a bit different. In the example I mentioned with your two photons it is assumed that the photons kick at the same time. But under such a boost that you suggest, presumably parallel to the direction paralle to the photons motion, simultaneity is not conserved.
See
http://www.geocities.com/physics_world/photon_in_box.htm
Actually, this question also bothered me in a different way. I did not bother about how to derive the effect like Arcon did.
I was bothered by that when two photons in exact wave length and different phase actaully will supercede each other and look like no photons or light waves at all.
But since there is a phase difference, I would guess their original emited time need to be different. Will this resolve the issue?
Or if, we carefully do it, maybe we can emit two EM waves at the same time but their phases will be completely in reverse and cancel out the EM waves and make no EM effects on a conduitnearby. Is this possible?
Thats the basics of interference, Sammy. I don't think it can be made to work in the way you suggest, but it does work.
Arcon,
In reading your "Gravitational Force", I found you lower the force index in your EQ (1), so it now seems to be a 1-form. Also, comparing it with Sean's lecture note, the Chris.. connection is a plus item not a minus item. Is it a result of lowering the index?
Originally posted by Sammywu
Arcon,
Yes. The reason is because this must hold in all limits, especially in the weak field limit. When you take the derivative of the Lagrangian with respect to xu the result is the generalized force and such a force is neccesarily a 1-form. In the weak field limit you treat the Lagrangian as a scalar field on a flat spacetime background. Taking the derivative with respect to xu produces a 4-force in that sense. That force is a 1-form. This also makes it consistent with how the generalized 4-force is defined in special relativity.
I don't see what you mean. Perhaps you're confusing the sign in the covariant derivative with the sign in the Christoffel symbol?
If V is a vector and p is a 1-form then
[tex]V^{\alpha}_{;\beta} = V^{\alpha}_{,\beta} - V^{\mu}\Gamma^{\alpha}_{\mu \beta}[/tex]
[tex]p_{\alpha;\beta} = p_{\alpha,\beta} - p_{\mu}\Gamma^{\mu}_{\alpha \beta}[/tex]
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 58 ·
9K
10K
  • · Replies 48 ·
