Calculating Max Height in Relative Projectile Motion: Earth vs. Moving Elevator
The discussion revolves around a problem in classical mechanics involving projectile motion and relative motion. A body is thrown vertically upward from the Earth's surface while an elevator moves upward at a constant speed. The objective is to determine the maximum height the body reaches relative to the elevator's floor.
  • Mixed
  • The original poster presents two potential solutions, calculating the maximum height of the body relative to the elevator using different methods. Some participants question the assumptions made in the first solution regarding the timing of reaching maximum heights.
There is ongoing debate regarding the validity of the two proposed solutions. Some participants assert that the second solution is correct, while others defend the first solution, leading to a lack of consensus. Participants are exploring the implications of using different frames of reference and the timing of events in the motion of the body and the elevator.
Participants mention the need for a strong argument to counter a teacher's insistence on the first solution being correct. There is a focus on classical mechanics without involving relativity.
chem3
Hello,
This is my first post here and I have the following question, please:
A body is thrown vertically upward from the surface of the Earth with an initial velocity of 7 m/s. Simultaneously an elevator cab starts to move upward from the same height the body was thrown from (the surface of the earth) with a constant velocity of 3 m/s. What is the max. height the body reaches relative to the cab's floor?
Two possible solutions I've thought of:
1- I calculated the max. height the body reaches relative to Earth's surface which was 2.45 m, and it took the body 0.7 sec to reach its max. height, and then I subtracted the height of the cab after 0.7 sec (= 2.1 m) from the 2.45 m max height and got 0.35 m as the max height of the body relative to the cab's floor.
or 2- I cosidered the cab as a frame of reference as it moves with a contant velocity, and that the body was thrown vertically with an initial velocity of 4 m/s (relative to the cab) and then used the equation:
V^2=Vi^2 + 2*g*H-max
with V=0 at max height and Vi=4 m/s (V of the body relative to the cab) and g=-10 m/s^2 we get:
H-max= max height = 16/20 = 0.8 m
Now, which solution is the right one (1 or 2 - 0.35 m or 0.8 m) and why?
Thanks in advance!
The second one is correct. Becouse in the first possiblety you falsely assume thet the maximum distance from the ground and the maximum distance from the elevatore are reached simultaneously, when in fact the maximum distance from the elevator is reached sooner.
Thanks for your reply LENIN!
Any other opinions, please?
Cause my teacher insists that the first solution is the right one, and I really need a strong argument (no relativity stuff please - all classical) to prove him wrong!
Well - considering Newton's classical equations of motion - the maximum height from the ground and the maximum height from the elevator are indeed reached simultaneously! AFAIK!
Any other opinions!
No they are not. When it's at the meximum distance from the elevator it's speed is 3 m/s upwards (relative to the ground) and when it's at maximum distance from the ground the speed is 0 m/s. As you can see the events can't be simultaneous.
As for the argument I believe that your argument about the cab as a frame of reference should suffice.
The second one is correct. I suggest you actually calculate how long it takes to reach the events described in the second solution, then show that, using the Earth as the frame of reference, they actually are separated by .8 m
Then you'll realize that it MUST be the correct answer, because .8 m is clearly greater than .35 m
Another way to look at it... when the ball is thrown up, it decellerates. However, at first it still travels faster than the elevator. Once the ball reaches a speed of 4 m/s, it travels slower than the cab. It is at this point that, instead of gaining distance on the cab, the cab begins to catch up to the ball, thus cutting down on the distance
28K
  • · Replies 22 ·
