Identifying an element from Emission Spectrum
The discussion centers on identifying elements from emission spectra using data collected from a spectrometer with a 100 lines/mm diffraction grating. The user has calculated wavelengths for the 1st and 2nd order lines of Blue/Violet, Green, and Orange colors but struggles to correlate these wavelengths with known emission spectra to identify the element. The user questions whether the spectrometer's resolution is inadequate and seeks a definitive method to match their calculated wavelengths with established spectral data, specifically referencing nitrogen.
  • Understanding of emission spectra and spectral lines
  • Familiarity with spectrometer operation and resolution
  • Knowledge of wavelength measurement techniques
  • Ability to interpret spectral data tables
  • Research methods for correlating calculated wavelengths with known emission spectra
  • Learn about the resolution limits of spectrometers and their impact on spectral identification
  • Explore databases of emission spectra, such as the NIST Atomic Spectra Database
  • Investigate techniques for enhancing spectrometer resolution and accuracy
Students and researchers in physics and chemistry, particularly those involved in spectroscopy, laboratory analysis, and elemental identification using emission spectra.
ness9660
Using data collected from a spectrometer, with a diffraction grating of 100 lines/mm, I have collected a set of data. From this I have calculated wavelengths for the 1st and 2nd order lines of the three brightest visible colors, which were Blue/Violet, Green, and Orange.
To complete my lab I am required to identify the element that produced the emission spectrum, however I am really unclear how to go about this.
So, I am left with wavelengths for 1st and 2nd order lines of each color, I've tried to compare this to lists of wavelengths for various emission spectrums I've found, but I see no way to take these wavelengths and positively identify my element. Most lists of wavelengths I find fall within the same range. What is the clear cut method that I am missing to correlate my wavelengths to another set given so as to identify my element?
is the spectrometer's resolution too poor or something? in general one should be able to identify elements pretty easily.
I can't really find any wavelengths to compare my calculated wavelengths to, just pictures of spectra, you can't make a positive id on that.
e.g.
I have a blue/violet 1st order to the right of center, wave length=348.99, and to the left of center=523.359.
Looking at this list:http://physics.nist.gov/PhysRefData/Handbook/Tables/nitrogentable2.htm for nitrogen, how can I even relate my 1st and second order measurements to the nitrogen table?
