What is the formula for finding the surface area of a surface of revolution?
The formula for calculating the surface area of a surface of revolution is defined based on the axis of rotation. When a function y = f(x) is revolved around the x-axis, the surface area is calculated using the formula A = 2π ∫ab f(x)√(1 + (f'(x))²) dx. Conversely, if the function is revolved around the y-axis, the formula changes to A = 2π ∫ab x√(1 + (f'(x))²) dx. Understanding the distinction between these two scenarios is crucial for correctly applying the formulas.
  • Understanding of calculus concepts, particularly integration
  • Familiarity with the concept of derivatives and arc length
  • Knowledge of functions and their graphical representations
  • Basic understanding of the geometry of surfaces of revolution
  • Study the application of the arc length formula in calculus
  • Learn about the properties of surfaces of revolution in geometry
  • Explore examples of calculating surface areas for different functions
  • Investigate the differences between rotating around the x-axis and y-axis
Students studying calculus, educators teaching mathematical concepts, and anyone interested in understanding the geometric properties of surfaces of revolution.
LittleTexan
Hello
can someone please give me some advice on applying the area of a surface revolution. I never seem to plugin the right formula.
In the formula S(from a to b) 2pi f(x)**sqrt(1 + f'(x)^2) I never know what to put for f(x)** some times the answers have just x and sometime it has the function of f(x).[/quote]
I don't know what you mean by "some times the answers have just x and sometime it has the function of f(x)." What does the problem itself have? In order to find the surface area of a "surface of revolution", you have to know what is being revolved! If you are given a function y= f(x), that is then revolved around the x-axis to form a 3 dimensional figure (the "surface of revolution"), then the surface area is given by that formula:
[tex]2\pi \int_a^b f(x)\sqrt{1+ f'^2(x)}dx[/tex].
The "f(x)" has to be given as a description of the curve, y= f(x), being rotated around the x-axis.
You probably know that the surface area of a cylinder, of radius r and length L is given by [itex]2\pi r L[/itex]: that's really the circumference of the circle times the length.
If y= f(x) is rotated around the x-axis, then each point describes a circle of radius f(x) and so circumference [itex]2\pi f(x)[/itex]. The length of a tiny ("infinitesmal") cylinder is given by the arclength formula: [itex]L= ds= \sqrt{1+ f'^2(x)}dx[/itex]. So the differential of area is given by [itex]dA= 2\pi f(x)\sqrt{1+ f'^2(x)}dx[/itex]. You integrate that to get the surface area: [itex]A= \int_a^b2\pi f(x)\sqrt{1+ f'^2(x)}dx[/itex].
HOWEVER, and this may be what is causing your confusion, if the graph of y= f(x) is rotated around the y-axis rather than the x-axis, each point follows a circle of radius x, not f(x). That circle has radius x, the distance from the point to the y-axis, not f(x), the distance from the point to the x-axis.
If you are given y= f(x), its graph being rotated around the x-axis, then the surface area is given by
[tex]2\pi\int_a^b f(x)\sqrt{1+ f '^2(x)}dx[/tex]
If you are given y= f(x), its' graph being rotated around the y-axis, then the surface area is given by
[tex]2\pi\int_a^b x \sqrt{1+ f '^2(x)}dx[/tex]
This post is confusing. Haven't you answered your own question?
