How Does Mercury's Density Affect Column Pressure in hPa?
The pressure of a 10 cm high column of mercury, with a density of 13.6 g/cm³, can be calculated using the formula Pressure = pgh, where p is the density, g is the acceleration due to gravity (9.81 m/s²), and h is the height in meters. The resulting pressure is expressed in hectopascals (hPa), where 1 hPa equals 100 pascals (Pa). The discussion clarifies that 'g' in the density unit refers to grams, not the gravitational acceleration.
  • Understanding of fluid mechanics principles
  • Familiarity with the formula for pressure (Pressure = pgh)
  • Knowledge of unit conversions between grams, centimeters, pascals, and hectopascals
  • Basic understanding of density and its units
  • Research the concept of hydrostatic pressure in fluids
  • Learn about unit conversions between different pressure units, including Pa and hPa
  • Explore the implications of density on fluid pressure in various applications
  • Study the effects of gravitational acceleration on pressure calculations
Students in physics or engineering, educators teaching fluid mechanics, and professionals involved in pressure measurement and analysis.
teng125
What is the pressure of a 10 cm high column of mercury
(ρ = 13,6 g/cm^3) in hPa?
i know that the formula is Pressure=pgh so i subs in 13.6g/cm^3 (9.81m/s^2) (10cm).
may i know what is the g in 13.6g/cm^3 belongs to??
is it equals to 9.81m/s^2??
and also what is hPa??i know Pa is pascal but don't know h
anybody pls help
thanx
hPa is 10^2, so 100 times a Pa. And assume g is 9.81ms^-2. I'm not sure what you mean "what the 'g' in 13.6g/cm^3 belongs to" question, but g is not a variable in there, it's an indication that the density is in grams per centimeter cubed, so keep the units in centimeters and grams, and the answer should be ok.
Levi
  • · Replies 18 ·
