| Thread Closed |
the problems with 100% pure ethanol |
Share Thread | Thread Tools |
| Jan19-04, 12:14 AM | #1 |
I was reading that ethanol can only be purified up to something like 95% by distillation and further purification calls for CaO. Why is this? Is CaO a drying agent? Why is it that you can't seperate water completely from ethanol?
Is it just not feasible without CaO, like the tiny amount of water is nearly impossible to remove due to their being so much ethanol around it. Their structures are similar, they both are polar with the OH group and there are few carbons on the ethanol so they are pretty miscible (sp?). So I guess I can see how water would have trouble breaking free of its bond to ethanol in solution, at such a low concentration. I can see it, but is it right? |
| PhysOrg.com |
chemistry news on PhysOrg.com >> New method for producing clean hydrogen >> Making ice-cream more nutritious with meat left-overs >> Non-wetting fabric drains sweat |
| Jan24-04, 02:49 AM | #2 |
At the concentration of 95% ethanol, water and ethanol form what is known as an azeotrope. This is a mixture in which the azeotrope distills off before the desired liquie (ethanol). Citing from my memory, ethanol boils at 78.3C and the azeotrope of 95% ethanol/water boils off at 78.15C. So you really neevr can get 100% ethanol from distillation because the azeotrope has a lower boiling point and so you have to use a dehydrating salt (CaO).
Thank you GOOGLE. |
| Jan26-04, 06:25 AM | #3 |
You should be aware that in any given substance (be it solid, liquid or a gas) that the atoms/molecules in it are all moving at different speeds (even if they all have the same Mr). This means that they all have different Kinetic Energies.
In a liquid some particles may have enough Kinetic Energy to break free of the surface of the liquid, that is why if you have a puddle of water, the water will evaporate over time. Of course, the higher the temperature of the liquid, the more likely it is that a particular atom/molecule will have the required Kinetic Energy to break free. So in the case of the azeotrope you mentioned, when the mixture is heated up to evaporate the ethanol, some of the water molecules evaporate as well. As you continue heating, more water evaporates with the ethanol and eventually you end up condensing 5% water and 95% ethanol. For more information, search for "Boltzman Distribution Curves" on google. Here is a pretty good Java applet for showing you the rms speeds of particles - http://comp.uark.edu/~jgeabana/mol_dyn/KinThI.html. |
| Jan28-04, 06:36 PM | #4 |
Pure ethanol can be prepared by adding benzene to a mix of 95% ethanol and water and then distillijng this solution. Benzene will for a different azeotrope with ethanol and water (7.5%). This boils at 64.9 C and allows removal of water along with some ethanol. Eventually pure "absolute alchol" is distilled over.
Nautica |
| Jan28-04, 07:29 PM | #5 |
Would a fractional distillation device allow, a closer approach to 100%, just slightly greater then 95%, or no real difference??
| Jan28-04, 07:31 PM | #6 |
No, it would not. It takes the fractional distillation to get to the 95%. The problem is that the Boiling point of the azeotrope is lower than the ethanol, so you get both through you distillation.
Nautica |
| Jan29-04, 05:39 AM | #7 |
| Jan29-04, 07:41 AM | #8 |
Yes, that is the purpose. The problem with this azeotrope, is that the azeotrope BP is slightly less than that of 100% ethanol, so the azeotrope becomes the product instead of what is left behind.
Nautica |
| Jan29-04, 08:01 AM | #9 |
Thank you...
| Mar11-09, 05:30 PM | #10 |
Hello, I have a question that is actually the same question as what was asked however. How do they know what the boiling point is of "pure" ethanol if they cannot produce "pure" ethanol?
| Mar11-09, 05:43 PM | #11 |
One can produce pure ethanol. One way it is done by azeotropically distilling the water from the 95% azeotrope with something like benzene, for example.
| Mar11-09, 05:52 PM | #12 |
But what happens to the benzene? And will I get 100% pure alcohol or do I approach the 100%?
| Mar11-09, 06:42 PM | #13 |
Recognitions:
| Mar11-09, 06:46 PM | #14 |
You mean that it is 100% pure ethanol right? Can you give me a technique that can give us pure ethanol? And after producing pure ethanol what do I have to do to keep it pure?
| Mar12-09, 02:50 AM | #15 |
Recognitions:
To keep it at 100% you'd need to keep it away from water, including air that has water in it. |
| Mar12-09, 02:56 AM | #16 |
Admin
Put ethanol over some dehydrating agent.
Then just keep it tighlty closed. |
| Mar12-09, 11:29 AM | #17 |
Of course, you're not going to drink this, right? Using benzene is dangerous and unless you have some sophisticated equipment to analyze the resulting ethanol, you never know if you are getting some cancer-causing benzene in your ethanol. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: the problems with 100% pure ethanol
| 100% ethanol ?? | Chemistry | 10 | ||
| Ethanol for drinking, Ethanol for fuel. | Chemistry | 7 | ||
| open problems in pure logic. | Set Theory, Logic, Probability, Statistics | 4 | ||
| pure and not pure states, an example | Quantum Physics | 4 | ||
| How to make ethanol...? | Biology | 2 | ||
