Proton in Magnetic field - am I correct?
The discussion centers on calculating the kinetic energy of a proton moving in a magnetic field of 1.10 T with a circular path radius of 4.5 cm. The correct formula for velocity is derived from the balance of magnetic and centripetal forces, leading to a calculated velocity of 4.7 x 106 m/s. The kinetic energy is subsequently computed as 1.878 x 10-14 J, which converts to approximately 1.17 x 105 eV. Discrepancies in charge value and conversion calculations were noted, emphasizing the importance of accuracy in physics calculations.
  • Understanding of magnetic fields and their effects on charged particles
  • Familiarity with the concepts of centripetal force and magnetic force
  • Knowledge of kinetic energy equations in physics
  • Basic proficiency in unit conversions, particularly between joules and electron volts
  • Study the Lorentz force and its implications in charged particle motion
  • Learn about the principles of circular motion in magnetic fields
  • Explore advanced kinetic energy calculations for particles in varying magnetic fields
  • Investigate the significance of precision in scientific calculations and common pitfalls
Students and educators in physics, particularly those focusing on electromagnetism and particle dynamics, as well as anyone involved in experimental physics requiring accurate energy calculations.
Poobel
Proton in Magnetic field -- am I correct?
One of my Physics ISU questions is as follows:
- A proton moves in a circular path perpendicular to a 1.10 T magnetic field. The radius of the path is 4.5 cm. calculate energy of the proton in eV
Well i had hard time doing it but here we go: my solution
mV^2/r=QrB V=QrB/m
V= (1.6x10^-16) x o.o45 m x 1.10 T) / 1.67x10^-27 kg
V= 4.7x10^6 m/s
Ek= 1/2mV^2 = 1/2 x 1.67x10^-27 kg x (4.7x10^6 m/s)^2
= 1.8x10^-14 J
Ek= 1.87x10^-14J x eV/1.6x10^-19J = (1.87x10^-14J)/ (1.6x10^-19J)
eV=1.3x10^5 eV=1.3x10^5
Fellow physisists is my solution correct?
Thank you
Hmm...I got close to 1.17*10^5 eV
Here's how I did it:
We want to know the kinetic energy of the proton, so:
[tex]E_{k}=\frac{1}{2}mv^2[/tex]
We know the mass of a proton is 1.67*10^-27, so the variable we need is the velocity at which it is travelling.
As this proton is moving in a circle in a magnetic field,
[tex]F_m=F_c[/tex] (where [tex]F_m[/tex] is the magnetic force and [tex]F_c[/tex] is the centripetal force
representing these with equations, we have
[tex]qvB=\frac{mv^2}{r}[/tex]
now, we isolate v, since that is what we are trying to get
[tex]v=\frac{qBr}{m}[/tex]
substituting into the kinetic energy equation, we get
[tex]E_{k}=\frac{1}{2}m(\frac{qBr}{m})^2[/tex]
which reduces to
[tex]E_{k}=\frac{(qBr)^2}{2m}[/tex]
substituting in,
[tex]E_{k}=\frac{((1.6*10^-19)(1.10)(0.045))^2}{2(1.67*10^-27)}[/tex]
which gets 1.878*10^-14 J
since 1 eV = 1.6*10^-19 J, the answer in eV is
(1.878*10^-14)/(1.6*10^-19) = 117,375 eV (1.17*10^5)
There are two things about yours that confuse me. First off, the magnitude of the charge on a proton is the elementary charge, which is 1.6*10^-19, whereas you have it as 1.6*10^-16...and yet you get the same energy in joules. Then at the end when you do your conversion from joules to electron volts, there seems to be a discrepency of some kind, because (1.87*10^-14)/(1.6*10^-19) does not equal 1.3*10^5. Also, I would have rounded to 1.88*10^5 if I were rounding. Apart from that the solution the same as mine.
Ok I'll look more into it
thanks a bunch, help is always appreciated
BTW that -16... I just copied it wrong from my notes:smile:
Hmm also you must've read my first post wrong since
  • · Replies 26 ·
  • · Replies 21 ·
47K
