Gram negative bacteria and antibiotics?
Gram negative bacteria possess a lower concentration of peptidoglycan in their cell walls compared to gram positive bacteria, which results in a pink stain after Gram staining. The presence of an outer membrane in gram negative bacteria provides a protective barrier that enhances resistance to antibiotics by preventing their access to the cell wall. This outer membrane effectively blocks antibiotics that target cell wall synthesis, making gram negative bacteria more resilient against such treatments. The discussion also touches on the role of iodine in the Gram staining process.
  • Understanding of Gram staining techniques
  • Knowledge of bacterial cell wall structure
  • Familiarity with antibiotic mechanisms of action
  • Basic microbiology concepts
  • Research the structure and function of bacterial outer membranes
  • Study the mechanisms of antibiotic resistance in gram negative bacteria
  • Learn about the role of iodine in the Gram staining process
  • Explore the implications of antibiotic resistance in clinical settings
Microbiologists, healthcare professionals, and anyone interested in understanding antibiotic resistance mechanisms in gram negative bacteria.
fish
A high level of peptidoglycan (polysaccharide) in the cell wall of bacteria will be stain gram positive (purple). Cells with a lower concentration of peptidoglycan in the cell walls are gram negative (pink).
Gram negative cells have an outer membrane that is toxic to mammalian physiology and helps protect cells from antibiotics.
How does having a lesser concentration of the polysaccharide in the cell walls (gram negative) give it more resistance to antibiotics? Is it because a thinner cell wall will give less protection against mutagens so the cell is more likely to survive the antibiotics?
Biology news on Phys.org
This is not the difference between gram positive and gram negative. the peptidoglycan in gram positive is directly expose to the environment whereas the peptidoglycan is gram negative is covered by the outer membrane. The outer membrane will not allow the purple stain to come in before the acohol wash.
As you said it is the outer membrane that give a better protection against the antibiotics that target cell wall. The OM block the action of the antibiotic by making the cell wall less available to the substrate.
yes , what he said was right .i also thinkthat even if low amounts of dye did penetrate OM ,it wud b pulled by dehydating acid alcohol . here cud u tell me wat is function of iodine ?
14K
