C - Speed of Light: Is Time Relative?
  • Context: Graduate
  • Thread starter Thread starter Tzemach
    Relative
The discussion revolves around the implications of the speed of light potentially changing, as suggested by Prof. Davies, and the relationship between time and speed in the context of special relativity (SR). Participants explore the nature of time as relative and its connection to the speed of light, while also addressing the foundational principles of SR and the controversy surrounding Davies' claims.
  • Some participants propose that the speed of light could be viewed as the speed at which we travel through time, questioning if this perspective is valid.
  • Others argue that the constancy of the speed of light is a fundamental postulate of SR, and time dilation is a consequence rather than a cause, emphasizing the need to maintain this distinction.
  • A participant challenges the derivation of the Lorentz factor solely from the constancy of the speed of light, suggesting it is mathematically impossible.
  • Concerns are raised about the implications of Davies' claims, with references to other works that contradict his assertions, particularly regarding the fine-structure constant and its relation to changing physics.
  • Some participants discuss the potential for light to travel at different velocities based on energy, referencing ongoing research and its implications for theories like loop quantum gravity (LQG).
Participants express differing views on the interpretation of the speed of light and its implications for time and relativity. There is no consensus on the validity of Davies' claims or the foundational aspects of SR, leading to an unresolved discussion.
Participants highlight the complexity of distinguishing between changing units and changing physical constants, as well as the operational significance of dimensionless quantities versus dimensionful quantities in physics.
Tzemach
Ever since Prof. Davies paper suggesting that the speed of light has changed was published I have been playing with some figures and would like to get some opinions.
We all accept that time is relative, if speed is V=d/t then velocity (speed) is dependent on our unit of time in this instance the speed of light is actually the speed at which we are traveling through time, or am I missing something?
You are putting the cart before the horse, and turned the effect into the cause.
Look at the postulate of SR. You'll see clearly that (i) c is a constant in all inertial reference frame and (ii) time dilation is NOT part of the postulate. This means that the starting point here is the constancy of the speed of light, and one of the consequences of that postulate is the time dilation effect.
I'm sure you can see now why turning the tail end back into the head, and using the effect to change the cause, does not really make any sense.
As for Davis's claim, it is still highly controversial (I've listed several recent publications that contradict this on here), and it has more to do with the fine-structure constant that might have changed over time than anything else. Even if this is true, it is still a major jump from the fine structure constant changing to c changing with time.
Zz.
Well in all fairness ZapperZ you really cannot derive the Lorentz factor from the postulate of the constancy of the speed of light alone. That is simply a mathematical impossibility.
Where did I say one could?
Zz.
Is it simpler to deduce the constancy of time?
Tzemach said:
Ever since Prof. Davies paper suggesting that the speed of light has changed was published ...
it, to say the least, is controversial. I'm more of the mind of Michael Duff, who, in my opinion blew Davies' claim out of the water with a very sensible fundamental argument that Davies is confusing choice of units with meaningful reality in physics:
The failure to tell the difference between changing units and changing physics is more than just semantics. It brings to mind the old lady who, when asked by the TV interviewer whether she believed in global warming, responded: “If you ask me, it’s all this changing from Fahrenheit to Centigrade that’s causing it”.
when we measure or perceive anything, we are measuring dimensionless numbers. we are measuring or perceiving one (usually dimensionful) physical quantity against a like dimensioned standard (sometimes called a "unit"). a variation in the fine-structure constant, [itex]\alpha[/itex] or the ratio of particle masses (such as [itex]m_p/m_e[/itex]) is something that has operationally meaningful consequence. the variation of a single dimensionful quantity, in and of itself, does not. and blaming any conceivable variation in a dimensionless "constant" such as [itex]\alpha[/itex] on any single component, is not meaningful. if [itex]\alpha[/itex] has changed, there is no meaningful differentiation between saying it because of changing [itex]e[/itex] or [itex]c[/itex] or [itex]\hbar[/itex]. we cannot know.
We can add that it is a fact that can permit and even predict some versions of theories like LQG and other. If my memory is not so bad, some people in the Imperial College were working on the possibility of light traveling at different velocities (acording to the energy carried), I'm not sure that Fortini Markopolu examined the idea there, but some people considered the implications and even the possibility of experimental detection of it -the effect becomes accumulative for long cosmological distances for the calculations in LQG-. I don't know if that was the idea when tzemach started the post. If it was the case, resulted inaforutnated the metion of Davies.
You only need two principles. The constancy of the speed of light and the principle that the laws of physics are the same for all inertial observers (i.e., observers agree on events). That and some algebra.
  • · Replies 25 ·
  • · Replies 29 ·
  • · Replies 57 ·
  • · Replies 42 ·
  • · Replies 18 ·
