What Factors Affect Load Sliding in a Van During Acceleration?
  • Context: Undergrad
  • Thread starter Thread starter shornoff
    Load Physics
The discussion revolves around the factors affecting load sliding in a van during acceleration, focusing on the relationship between mass, friction, and acceleration. Participants explore theoretical and practical aspects of static and dynamic friction, as well as the implications of different load characteristics on sliding behavior.
  • One participant states that the load inside the van experiences a force due to acceleration, leading to a condition where sliding occurs when the force exceeds the frictional force.
  • Another participant notes that coefficients of friction may not remain constant under varying normal forces, suggesting that surface imperfections play a role in friction behavior.
  • A claim is made that total friction is the product of the coefficient of friction and the normal force, indicating that heavier loads require greater forces to overcome friction.
  • Some participants argue that while the initial math suggests that the acceleration at which sliding occurs is independent of mass, practical observations indicate that lighter objects may slide more easily than heavier ones due to differences in contact and friction coefficients.
  • Concerns are raised about the complexities of friction problems, including the effects of load shape, surface contact area, and rotational dynamics when cornering.
  • One participant discusses the acceleration of F1 cars, questioning how they can achieve accelerations greater than μg and suggesting that the coefficient of friction must be greater than 1 to satisfy this condition.
Participants express differing views on the relationship between mass and sliding behavior, with some asserting that mass does not affect the acceleration threshold for sliding, while others point out practical considerations that suggest otherwise. The discussion remains unresolved with multiple competing perspectives on the factors influencing load sliding.
Participants acknowledge various limitations in their analyses, including the dependence on surface conditions, the variability of friction coefficients, and the influence of load characteristics on sliding behavior. These factors complicate the theoretical models presented.
shornoff
I drive a van. When I accelerate the load inside my van of mass M must be accelerated at acceleration A which is the same as the acceleration of my van by a force F1, where F1=MA.
The mass M has a reactive force Mg on the floor of the van and so the force, F2 needed to make it slide is over the floor is μMg where μ is the coefficient of static friction.
My load will slide when F1 is greater than F2. So the load starts to slide when F1=F2 or MA=μMg. In other words after the M's cancel the acceleration at which my load starts to slide is independent of it's mass. All loads will slide when the van has an acceleration greater than μg.
But I know that light things slide all over the place whereas 2 tonne masses of iron tend to stay put.
So what is wrong with my logic?
even though we model it as constant, the coefficients of static friction (not sliding) or dynamic friction (sliding) are not truly constant when the normal force (from weight) exerted between surfaces gets very large. (probably i should say when the pressure, the normal force per unit area, gets very large.) this is because little imperfections in the contact surfaces that dig into the other surface a little.
try the same experiment with a nice smooth and dry surface on the bed of your van like a smooth sheet of plywood and with identical smooth bottom surfaces of the different sized objects. the smoothest and most consistent surface texture the better. i think in this case, you might have less difference in sliding between different sized masses, but be careful with a 2 ton mass.
The total friction is the product of the coefficient of friction and Normal force, hence
[tex]f=\mu N[/tex]
Therefore the heavier your load, the greater the force needed to overcome friction.
Also,
[tex]f _{static} > f_{kinetic}[/tex]
Therefore
[tex]F_{static} > F_{kinetic}[/tex]
In other words, once your load starts moving, it will accelerate till it hits the side of your van if you take no action to alter F.
Thanks for that WhyIsItSo.
I agree, but also the heavier the load the greater the force needed to accelerate it. If my original maths is correct then the masses cancel and the acceleration at which the load slides is independent of its mass.
Similar problem with F1 (or Indy etc.) cars. How can they accelerate from a standing start (no wing down force) at an acceleration greater than μg? I'm pretty sure they do, so I'm wrong somewhere!
It is independent of it's mass. The lighter objects must not have the same static coefficient of friction as the iron. Here's a better test: Take two identical plastic containers. leave one empty and put a few bricks in the other one. They will both start to slide around at the same acceleration.
Your math is correct (if messy:wink: ). Let's revisit:
[tex]a=\frac{F}{m}[/tex]
and also:
[tex]f_{friction}=\mu N[/tex]
So for a constant acceleration, doubling the mass doubles the force but also doubles the friction.
The problem lies in the difficulties of "friction" problems. There are so many variables to consider. For example, in practice, a heavier load probably makes better contact with the bed of your van, so [tex]\mu[/tex] is probably higher than for, say, a light cardboard box whose base is not making contact with the bed of your van in some places. Also, the math does not consider rotational effects on you load. When you take a corner, your load wants to tip over. My math is not sufficient to calculate the effect on the friction formula, but it may well paint a very different picture. The area of the base of different loads is another factor. The weight of a heavy load makes your van ride smoother, therefore the Normal downward force does not change as much due to the acceleration issues of "bouncing" over a surface; remember that it takes more force (usually) to overcome friction from rest than it does to keep that mass moving, so lighter load is more likely to experience a "moment" when static friction is overcome. And let's not forget that the material is a determing factor for [tex]\mu[/tex].
Once again, the math is not necessarily going to give you a practical answer, since we can't take deal with all the variables. That said...
Work the problem from the "right" direction. What value of [tex]\mu[/tex] gives me enough a to satisfy your condition?
I did a quick search and came up with a weight of 1550Lbs = 703Kg for an Indy car. Good enough. Take [tex]a=9.8m/s^2[/tex]. On a flat, horizontal surface then:
[tex]\mbox{From }F=ma[/tex]
[tex]F=(703)(9.8)=6889.4[/tex]
That is both the Normal force due to weight contributing to friction, and the horizontal force we need to exceed to satisfy your scenario. Turns out the Indy car can accelerate at better than [tex]9.8m/s^2[/tex] when [tex]\mu>1[/tex].
I had a look at some coefficient of friction tables, and discovered materials like aluminum on aluminum have values above 1. And since we've shown that changing mass has no effect on the acceleration we can achieve before the tires spin, making the Indy car lighter (or heavier) doesn't help. [tex]\mu>1[/tex] is still required.
But I reckon the tires on an Indy car are a lot "stickier" than that!
  • · Replies 21 ·
  • · Replies 17 ·
