Slope of Tangent Line for y = sin(2πx) at x = 1 and x = 2
The discussion revolves around finding the slope of the tangent line for the function \( f(x) = \frac{1}{x} \) at the point \( a = 2 \), as well as exploring the concept of secant lines and their relationship to tangent lines, particularly in the context of the sine and cosine functions.
  • Homework-related, Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant attempts to calculate the slope of the tangent line using the limit definition but encounters difficulties with algebraic manipulation.
  • Another participant questions whether \( \frac{1}{2} \) is equivalent to \( \frac{1+h}{2+h} \), indicating confusion over algebraic steps.
  • Several participants discuss the need for a common denominator in their calculations, with one noting that a factor of \( h \) is necessary for the denominators to match.
  • A participant raises a question about secant lines intersecting two consecutive points on a curve, leading to a discussion about the nature of points on a curve and the concept of derivatives.
  • Another participant suggests that if two points on a curve have equal derivatives, the tangent lines at those points could potentially have the same y-intercept, thus forming a secant line.
  • There is a proposal that the function \( y = \sin(2\pi x) \) has equal derivatives at \( x = 1 \) and \( x = 2 \), which leads to further exploration of tangent lines and secant lines.
  • A later reply introduces \( y = \cos(2\pi x) \) as an example where the tangent line at two points has the same y-intercept, prompting further clarification and examples from participants.
Participants express varying levels of understanding regarding the calculations for the slope of the tangent line, and there is no consensus on the initial problem. The discussion about secant lines and their relationship to tangent lines reveals multiple competing views and interpretations, particularly regarding the definition of consecutive points on a curve.
Limitations in the discussion include unresolved algebraic steps, confusion over definitions of consecutive points, and the dependence on specific functions for examples of tangent and secant lines.
DB
really isn't calculus but that's the name of my class so, anyway I am having a problem here. i think its pretty simple I am just missing something. I am supposed to find the slope of the tangent line using one point and:
slope of tangent line =
[tex]\frac{f(a+h)-f(a)}{h}[/tex]
[tex]h\rightarrow0[/tex]
find slope of tangent line:
[tex]f(x)=\frac{1}{x}[/tex]
at a=2
so,
[tex]\frac{1}{2+h}-\frac{1}{2}*\frac{1}{h}[/tex]
common denominator X by (1+h)
[tex]\frac{1}{2+h}-\frac{1+h}{2+h}*\frac{1}{h}[/tex]
[tex]\frac{1-1-h}{2+h}*\frac{1}{h}[/tex]
[tex]\frac{-2-h}{2+h}*\frac{1}{h}[/tex]
[tex]\frac{-1(2+h)}{2+h}*\frac{1}{h}[/tex]
[tex]\frac{-1}{h}[/tex]
make "h" zero and I am stuck...
Ummm... Is 1/2 the same as (1+h)/(2+h)?
thanks
okay stupid mistake, now I am stuck again tho
[tex]\frac{2}{2(2+h)}-\frac{(2+h)}{2(2+h)}*\frac{1}{h}[/tex]
comes out to
[tex]\frac{-1}{h}}*\frac{1}{h}[/tex]
gives me -1/h which doesn't work, darn
You need a factor of h in the first denominator for the denominators to be equal.
i don't understand
The denominator of the first term expanded is (4+2h) while the second term's denominator is (4h+2h2)
but those are different terms, arent i looking for a common denominator?
If [tex]f(x)=\frac{1}{x},[/tex] then
[tex]\frac{f(a+h)-f(a)}{h} = \frac{\frac{1}{2+h}-\frac{1}{2}}{h} = \frac{1}{h(2+h)}-\frac{1}{2h} = \frac{2-(2+h)}{2h(2+h)}[/tex]
[tex]=-\frac{1}{2(2+h)}\rightarrow -\frac{1}{4} \mbox{ as }h\rightarrow 0[/tex]
Yes which is why you need to multiply the first term by h/h so that you have a common denominator.
thanks for the replies, but i don't understand how the c.d is 2h(2+h)
finally, got it
I was wondering one thing about tangent line. Since tangent lines can also be secant line, I actually had a question about secant line. Is it possible for a secant line to intersect 2 consecutive points of a curve? I guess what I am trying to get to is, in a curve, can two, next to each other points be in a straight line?
What do you mean by two consecutive points? Between any two points on a curve there are an infinite number of other points so there really isn't such a thing as consecutive points in the way you are probably thinking. But if you mean like 2 points on a curve where say x = 1 and x = 2, then sure you just have to find a function with equal derivatives at those points, I can't think this through completely right now but that's the gist of it.
Can you give me an example?
Can you give me one of what you mean by consecutive points?
Are you referring to something like y=sin(2πx) ?
It has equal derivatives at x=1 and x=2 (i.e., y'(1)=y'(2)=2π)
No not quite, since that gives a nice counterexample to what I was thinking, errr... I guess not what i was thinking but what I wrote since what I was thinking was that if there are two points on a curve, if the derivative at both of these points are equal and the tangent lines at each point have the same y intercept then they must be the same line and the tangent line would be a secant line. With a sine function like the one you mention you'll have the equal derivatives and hence slopes of the tangent lines are the same but the y intercepts are different. But again with that same function consider y=1 this will be tangent to that curve for x=1/4+n where n is an integer, but this probably isn't quite what the original poster was talking about and isn't exactly what i was either. If you still don't get what I mean I'll try and write up a better post and find a good example of this tomorrow.
:smile: Perhaps you were thinking of y=cos(2πx) ?
Where y'(1)=y'(2)=0 and the single line y=1 is tangent to y(x) at x=1 and x=2
(generally, as y=1 is tangent to y(x) here for all integer 'x')
Well y=1 is tangent to sin(2πx) for all x of the form 1/4+n where n is an integer, isn't it? Because you would have sinn(π/2 + 2πn) which is 1 for every integer n, isn't it? You're example works to, and is better than mine since you don't have to have the 1/4 part.
  • · Replies 53 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 22 ·
