Planet or Star: How to Tell the Difference When Stargazing?
  • Context: High School
  • Thread starter Thread starter NanoTech
    Planet Star
The discussion revolves around how to differentiate between planets and stars when stargazing. Participants explore various observational clues, positional information, and personal experiences related to identifying celestial objects. The scope includes conceptual understanding and practical tips for amateur astronomers.
  • Homework-related
  • Some participants suggest that planets can appear brighter than stars, with Venus and Jupiter being notable examples.
  • There is a claim that planets do not twinkle as much as stars due to their angular size being larger than that of stars.
  • Positional clues are discussed, such as Venus being located in the same half of the sky as the sun and the significance of the ecliptic stripe where planets are typically found.
  • One participant notes that the orbits of planets are not perfectly aligned with the ecliptic, leading to potential deviations up to 18 degrees north or south.
  • Several participants mention the importance of familiarizing oneself with constellations and using star maps to aid in identification.
  • Some participants share resources for software and guides that can assist in stargazing and identifying celestial objects.
  • There is a brief mention that stars twinkle while planets do not, which is presented as a simple rule of thumb.
Participants express various viewpoints on how to distinguish between planets and stars, with no clear consensus on a single method. Some agree on certain characteristics, while others introduce different ideas and nuances, indicating ongoing debate and exploration of the topic.
Participants acknowledge that the definitions and characteristics of celestial objects can be complex and may depend on specific conditions such as location and atmospheric effects.
Astronomy enthusiasts, amateur stargazers, and individuals interested in learning more about celestial navigation and identification may find this discussion beneficial.
NanoTech
When looking in the sky, how would you determine if your seeing a planet or a star? Thanks.
Astronomy news on Phys.org
Hello NanoTech, there are probably several clues that different people use, some conscious, and others not so conscious and harder to put in words. Ideally you will get several answers.
It isn't completely reliable but planets can actually look different.
Venus is brighter than any star. Jupiter is too, sometimes.
Mars has a tinge of orange. I think of Jupiter's color as "cold" compared to Mars.
Some people say planets don't twinkle as much as stars and that would make sense because the angular size of stars is virtually zero---they are effectively point-sources. Though planets don't appear wider to the naked eye, the near ones have some measurable angular width.
The best clues probably have to do with position. There are really simple things like "venus is always in the same half of the sky as the sun". This makes it easy to recognize because after sundown, since its brighter than any star, it will probably show up in the sky before any star does and it will be in the western half of the sky.
Another positional clue is the ecliptic stripe in the sky, like a badly aligned equator going not-quite east-west. The "zodiac" constellations are distributed along it. It marks the plane of solar system so planets appear only in this band of sky. You get to know where the ecliptic stripe of sky is, which depends on your latitude
and a little bit on the time of year. Then anything you see that is not on the ecliptic has to be a star.
the ultimate postional clue is to have a mental picture of the main constellations. So if you see a bright "star" and it is someplace where no bright star belongs you can say its a planet.
(but first wait a bit to see if it moves because then its an airplane
or a satellite)
Ok, I overlooked that in my reading about the Zodiac. The reading says it is an 18 degree band centered on the ecliptic. I know that most of the planets do not revolve in a perfect plane. Does that mean some planets are displaced up to 18 degrees south or north of the ecliptic equator?
...I know that some planets are farther up and down than other, hence they aren't all in one plane.
that is right. the ecliptic is simply the plane of the Earth's orbit. the other planets orbits are each tilted slightly from that
but (and someone else please correct me if I am wrong) the other planets are very nearly all in the same plane (except that weird one that you never see anyway, Pluto)
so because the are very nearly in the same plane as the Earth they show up approximately along the ecliptic
celestial equator is different, being the projection of the Earth's equator. the ecliptic is skewed from the celestial equator
cocked at a jaunty 23 degree angle
I think I am just repeating stuff you know as well as or better than I
you probably have some ways of distinguishing planets from stars.
if so please share them.
Thanks for the posts Marcus and Jimmy. I'm still trying to get all of the astronomical definitons straight, I think it will take a while.. But I am thinking about getting a telescope and start observing the local celestial objects. I'll check out the Peterson's guide too, any idea how much that costs?
I didn't know they had freeware planetary programs online. I have a cheap Gateway Model(1.6 GHz), but I tuned it up with some memory and a video card. And I run Window XP(home edition). Yeah, I have saw a lot of field guides at the library but they were really outdated, from the 70's and 80's. I'm sure the software would be better because of patches and regular upgrades,that might be a better choice for me in the long run-- but at a higher cost I bet..
I didn't find the program I was looking for but I did find a better one. It's called WinStars:
http://www.winstars.net/english/index2.html
Here's a link to a great program that's completely free. It's not a planetarium program but it's excellent.
Celestia is a free real-time space simulation that let's you experience our universe in three dimensions. Unlike most planetarium software, Celestia doesn't confine you to the surface of the Earth. You can travel throughout the solar system, to any of over 100,000 stars, or even beyond the galaxy. All travel in Celestia is seamless; the exponential zoom feature let's you explore space across a huge range of scales, from galaxy clusters down to spacecraft only a few meters across. A 'point-and-goto' interface makes it simple to navigate through the universe to the object you want to visit.
http://www.shatters.net/celestia/index.html
Screen shots:
http://www.shatters.net/celestia/gallery.html
It's a 11 Mb download but it's worth it. There are tons of add-ons such as high-res planetary textures, star databases; I could list stuff all night. I'd recommend checking out the forum if you like celestia. It's a very detailed program.
If you have trouble downloading it from their page, try this link:
http://www.shatters.net/celestia/files/celestia-win32-1.3.1-1.exe
And a general astronomy site with lots of good links and info:
http://users.skynet.be/space-link/
If you want to know where anything is, look at:
http://www.heavens-above.com/planetsummary.asp?lat=27.947&lng=-82.459&alt=1&loc=Tampa&TZ=EST
It says Tampa, but just go back to the home page and enter your own location for the many other things you can access from there; sun, moon, planetarium, minor planets, etc. Very handy and its all on their computer, not yours.
For the best "planetarium" program with over 19 million objects, with current Hipparcos stats, precice planetarium program, positions of all solar system objects, etc., etc. try out Software Bisque's program called "The Sky", version 5, level 2. It is about $129 retail and takes about 700 meg, but it is worth it.
Welcome to Physics Forums, NanoTech! :smile:
Excellent response, marcus (as usual).
One of the most rewarding things you can do with a few summer night is to become familiar with the constellations and the major stars. You do not need any equipment other then a good star map. It does not have to be new because the constellations have not changed in written history. You only need some Patience and a clear night. In some ways it is better not to have TO GOOD of seeing conditions. I have noticed in the few times that I was in the high Cascade mountains on a clear summer night there were so many stars that it was HARDER to pick out the ones I was familiar with. On a slightly hazy night or near a city which creates a artificially bright sky the stars you can see are the bright ones. These are the stars you need to orient yourself. While you will never see Virgo or Cancer (in the proper season,of course) in these conditions you should be able to find Cygnus, Lyra and Aquila easily. The summer Triangle consisting of Vega (in Lyra), Deneb (in Cygnus) and Altair (in Aquila) is a good place to start.
I agree. The best way to start is learning the constellations with a good star guide. A pair of binoculars is nice to have, however, especially in the summer. There are lots of open clusters to view in and around the milky way.
I live in the city so when I go out to a dark site, I have to take a few minutes to get my bearing in the midst of all the other stars that are visible.
It's very simple!
Stars Twinkle and Planets don't. Also, planets are brighter than stars.
Info.
  • · Replies 19 ·
  • · Replies 17 ·
