Polar notation for a complex exponential function
The discussion revolves around finding the polar notation for the expression 1 + e^(j4), which involves complex exponentials and their representation in polar form. Participants are exploring the relationship between the complex exponential and trigonometric identities.
  • Some participants discuss the conversion of the complex exponential into trigonometric form, while others explore the absolute value and angle of the resulting expression. There are questions about the nature of the provided answers and their alignment with polar form.
Participants are actively engaging with the problem, offering various perspectives on how to approach the conversion to polar notation. Some have provided insights into the magnitude calculation, while others are questioning the clarity of the original problem and the answers given.
There is some confusion regarding the representation of answers in polar form, as participants note discrepancies between the expected format and the provided options. The discussion also touches on the use of trigonometric identities and the implications of different approaches to the problem.
Eng67
I am trying to find the polar notation for
1 + e^(j4)
I know that e^(jx) = cos x + jsin x
= cos(4) + jsin(4)
I can then find the magnitude and angle.
This is nowhere close to the answers below.
1) cos(2) + 1
2) e^(j2)[2cos(2)]
3) e^(-j4)sin(2)
4) e^(j2)(1+2cos(2))
Can anyone point me in the right direction?
So you know 1+e^(j4)=(1+cos(4)) + jsin(4). What is the absolute value of this number? (some trig identities will help). This will be enough to pick the answer from those 4.
You can go another way, if you pull out an e^(j2) you get:
1+e^(j4)=e^(j2)*(e^(-j2)+e^(j2))
do you see how this helps?
1 + e^(j4)
= cos(4) + jsin(4)
1) cos(2) + 1
2) e^(j2)[2cos(2)]
3) e^(-j4)sin(2)
This is a bit confusing. You say you want polar form: "magnitude and angle", which are both real numbers. Yet three of the "answers" you give are complex numbers and one is a single real number. What exactly do those "answers" represent?
[tex]r e^{j\theta}[/tex] where theta and r are real is sometimes called polar form/notation.
Yes, but none of the answers given are of that form.
[tex]e^{j\theta}r[/tex] then?
What are you seeing that I'm not?
Thanks Shmoe! I was able to work through to a solution.
I agree with HallsofIvy That this question is confusing.
Yes, the question is confusing but my remarks were incorrect and didn't help! As Shmoe said originally, 1+e^(j4)=(1+cos(4)) + jsin(4) which has modulus (absolute value)
[tex]\sqrt{(1+ cos(4))^2+ sin^2(4)}= \sqrt{1+ 2cos(4)+cos^2(4)+ sin^2(4)}[/tex]
[tex]= \sqrt{2+ 2 cos(4)}= \sqrt{2+ 2cos^2(2)- 2sin^2(2)}[/tex]
(using the double angle formula cos(2x)= cos2(x)- sin2(x))
[tex]= \sqrt{2(1- sin^2(2))+ 2cos^2(2)}= \sqrt{4cos^2(2)}[/tex]
[tex]= 2cos(2)[/tex]
Does that help?
That was the exact answer that I came up with!
Thanks all for the replies!
You should make sure you can find the angle as well, not all question will be multiple choice where the magnitude is enough to pick out the answer!
I prefer the route of my second suggestion:
And you know cos(z)=(e^(jz)+e^(-jz))/2, so you get answer 2) without having to muck about with double angle formulas that I would likely have to derive on the spot anyways.
9K
