Help! Coding a Program with Limited Knowledge of C/C++
The discussion focuses on creating a simple C++ program to read two inputs, "toll" and "norm", and write them to a file named "data.txt". The user seeks guidance on file handling, specifically how to overwrite an existing file and format the output correctly. The solution involves using the fstream library to manage file operations, with the ofstream class for output. The provided code snippet demonstrates how to open the file, write the formatted data, and suggests that explicit file closure is not necessary for simple programs.
  • Basic understanding of C++ syntax and structure
  • Familiarity with input/output operations in C++
  • Knowledge of file handling using the fstream library
  • Experience with data types and formatting in C++
  • Explore file handling in C++ using fstream and ofstream
  • Learn about formatting output with cout and file streams
  • Research error handling in file operations to manage exceptions
  • Study the differences between C and C++ for file I/O operations
Students learning C++ programming, beginners needing to understand file operations, and anyone looking to implement basic data logging in their applications.
omgitsroy326
I have a program due in couple hours. Professor expects us to know C++ when we never really went over programming; he expects us to just know it .. anyhow
I have two inputs used with scanf
it's toll and norm
these two values need to be put into a data file created by the program
I need a key that allows me to
create a "data.txt" file and if the file exist to overwrite it by erased etc.. doesn't matter and put in the things as
printf(" Toll = %e \m Norm = %e", toll, norm);
and just exit the program
i know it's coded in C... but that's all i know
anyhow if i can code in C or C++ doesnt' matter also could you tell me what library i can use.
Technology news on Phys.org
it's toll and norm
Hi omgitsroy
I don't have my C++ book on me, so the syntax may be a bit off.
Code:
#include <fstream> // File operations
ofstream output("data.txt" , ios::out) ; //Opens a file object 'output' to file "data.txt"
                                         //for output, overwrites if existing
output<<"Toll = "<< toll <<"\m  Norm = "<< norm << endl; //Outputs to file just like 'cout' command
I don't remember how to explicitly close the file, but I don't think it's really necessary unless your program is complex. Formatting can be done with standard i/o commands.
Hope that's all correct...
thanks a lot
  • · Replies 30 ·
