Calculating the Wattage Usage of a 60-Watt Light Bulb in Three Hours
The discussion revolves around calculating the energy usage of a 60-watt light bulb over a period of three hours, specifically focusing on the interpretation of wattage, kilowatt-hours, and the conversion to amps.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the calculation of energy usage in watt-hours and kilowatt-hours, questioning the initial framing of the problem. There are attempts to clarify the relationship between watts, joules, and amps, with some participants expressing confusion about the conversions involved.
The discussion is active, with various interpretations being explored regarding the calculations and conversions. Some participants have provided clarifications about the definitions of power and energy, while others question the assumptions made in the original posts.
There is a noted confusion regarding the relationship between watts, amps, and voltage, as well as the implications of different electrical standards in various countries. Participants are also navigating the distinction between power and energy usage.
marshall4
How may watts does a 60-watt light bulb use in three hours?
60*3=180watts?
Watts are a measure of power. Power is a rate of energy usage. "How many watts used in an hour?", is a nonsensical question.
Sensible questions would be:
-How many kilowatt-hours does a 60 watt bulb use in 3 hours?
-How many joules does a 60 watt bulb use in 3 hours?
Keeping in mind that a watt is 1 joule per second.
Njorl
how can i convert that to amps?
0.18
You can't.
60 watts for 3 hours is 60 * 3 = 180 watt-hours. That's the same as 0.180 kilowatt-hours.
Your next question, "how do I convert that [kilowatt-hours] into amps?" is as non-sensical as the first question.
- Warren
Amps = unit of current = rate of change of charge.
Volts = unit of electric potential
Joules = unit of energy.
Watt = unit of power = rate of change of energy
Kilowatt-Hours = Non-SI unit of energy
You cannot calculate current from power unless you know the voltage, or the resistance.
ya, I'm confused
Watts and amps are both rates. They both stay constant and do not change with time.
To find the amps, divide by the watts by 120.
Uh... hmm. This is true (as a simplification) in this case, but is not always true.
Not neccessarily. Depends on the country.
