Deoderant/pressurised container why does the liquid/gas come out
  • Thread starter Thread starter konichiwa2x
    Container
The discussion focuses on the mechanics of how deodorants in pressurized containers release liquid or gas when the knob is pressed, emphasizing the role of pressure differentials. When the knob is activated, a pathway is created, allowing the higher internal pressure to force the liquid or gas out. Additionally, the conversation confirms that high-pressure and low-temperature conditions can coexist, although achieving this in practice is challenging. The ideal gas law (PV=nRT) is referenced, highlighting the relationship between pressure and temperature in these scenarios.
  • Understanding of gas laws, specifically the ideal gas law (PV=nRT)
  • Knowledge of pressure dynamics in closed systems
  • Familiarity with the properties of gases and liquids under varying temperatures
  • Basic principles of thermodynamics related to pressure and temperature
  • Research the ideal gas law and its limitations under high pressure conditions
  • Explore the principles of pressure differentials in fluid dynamics
  • Investigate industrial applications of high-pressure gas systems
  • Learn about the thermodynamic properties of gases at low temperatures
Students and professionals in physics, engineering, and chemistry, particularly those interested in fluid dynamics and thermodynamics related to pressurized systems.
konichiwa2x
Hi, While using a deoderant/pressurised container why does the liquid/gas come out while we press the knob? And is a high-pressure and low-temp situation possible together?
Chemistry news on Phys.org
well I would imagine that when the knob is pushed a path from the inside pressureized cannister and the outside is created, then because of the pressure differential the gas/liquid is 'forced' out.
as for a high pressure, low temperature situation, these are entirely possible. The level of difficulty in creating these depends on the amount of pressure and how low of a temperature one would like. If you think of the basic equation PV=nRT (ignoring the fact that at really high pressures this equation doesn't hold exactly, but still the same principles apply) then at high pressure and low temperature in theory one would just need a small volume with many molecules. In practice this is hard to make. Industrial compressed air cylinders are usually around room temperature and highly pressured (the ones we use are 2500 psi when fresh).
Yes a high pressure-low temperature condition is possible. But remember that this simply means that P is simply higher than T; P is always direclty proportional to T.
13K
  • · Replies 0 ·
