Solving the Electric Field at Center of Square: Magnitude & Direction
  • Thread starter Thread starter GenMipps
    Electricity
The problem involves calculating the electric field at the center of a square configuration of charges, specifically with charges +q, -2q, +2q, and -q located at the corners of the square. The dimensions of the square are given, and the task is to determine both the magnitude and direction of the electric field at the center.
  • Participants describe their attempts to calculate the electric field using the formula E = kq/r², with one participant noting the importance of using the correct units for distance. There is discussion about the components of the electric fields from each charge and how they are summed to find the resultant field.
Multiple participants express confusion regarding their calculations, particularly about the magnitude of the electric field. One participant has pointed out a potential issue with unit conversion, suggesting that the distance should be in meters for accurate results. There is no explicit consensus on the correct approach yet, but guidance has been provided regarding unit considerations.
Participants are working under the constraints of a homework assignment, which may impose specific rules regarding the format of answers and the use of units. There is an acknowledgment of potential errors in calculations and assumptions made during the problem-solving process.
GenMipps
This homework assignment is killing me. I keep thinking I know what I'm doing, and I keep getting it wrong. If anyone can tell me how I goofed this one up, I'd appreciate it.
What they give in the figure is a square. Upper left is +q, upper right is -2q, bottom right is +2q, and bottom left is -q. Each side of the square is given as a. Then the question reads:
What are the magnitude and direction of the electric field at the center of the square of Fig. 23-30 if q= 2.21 x10-8 C and a= 4.25 cm ?
Now, What I did was drew myself a diagram of this, and rotated it 45 degrees clockwise, so E3 was pointing up, E2 was pointing to the right, E1 was pointing down, and E4 was pointing to the left. So, using E = kq/r2, I found the electric fields. R has to be 3 using pythagoram's theorem (4.25^2+4.25^2 then divide by 2).
So, I got E1 = 22.0754 N/c, E2 = -44.151, E3 = 44.151 and E4 = -22.054. Now, I drew a diagram with these, and found the horizontal components (E2 and E4) were summed together to 22.0756. The vertical components were summed together and found to be -22.0756. So, with x and y components, the resultant should be 31.22. I then subtracted 45 degrees again since I had rotated it at the beginning. That gave the direction in the vertical direction.
However, when I entered this answer in, I got the magnitude wrong, but the direction correct. Where did I slip up?
This just shows what I don't know. I thought the answer was 0. Sorry.
You must put the distance in *meters* in order to get the E field in N/C.
Patrick
Patrick
  • · Replies 23 ·
  • · Replies 17 ·
